  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,494   Was thanked: 1766 time(s) in 597 post(s)
New SMath Studio 0.97.5737 available Absolutely free mathematical program with "paper"-like interface and numerous computing features (now with integrated mathematical reference book). SMath Studio Desktop on the Desktop (Windows) SMath Studio Desktop on the Desktop (Linux) Latest changes (against to the latest nightly build: SMath Studio 0.97.5576) - Scrolling within Reference Book restored;
- Added ability to paste inside text element of MathRegion;
- Fixed issue appeared when newer version of built-in plug-in required for worksheet opening;
- Fixed issue when items from Menu > Insert not updated after new plug-in(s) installed;
- SS-170: Unwanted automatic Image region resize on file open to fit into printing bounds fixed;
- SS-2268: Broken equation on inserting factorial or boolean not operators for selected equation's part fixed;
- Displaying sum(1) and int(2) functions corrected;
- Internal: Symbol for 'minus/plus' operator changed from '%';
- '%' symbol can be used for variables, text and units inside Math region now;
- Handling of erorrs on evaluation performed by Custom Regions plug-ins improved (stability improvement);
- Language files updated;
- Regactoring.
Additional changes (against to the latest stable release SMath Studio 0.97.5346) - Ignore Units feature implemented for Math Region (required for engineers in some cases, when equation contains constants without specified units);
- High definition scrolling finally supported (scrolling was not possible with some Microsoft mouses);
- Added ability to delete installed plug-ins;
- Dialog with failed to load plug-ins allows to update them without opening Extensions Manager;
- Trailing zeros option of Math Region performs evaluation after change;
- Scrolling to focused region significantly improved;
- Displaying of simplification results improved for some cases;
- Replacements of units on copy/paste fixed (f.e. 'g->'g.e);
- Various critical errors fixed happened on paste of inconsistent equation part;
- Fixed calculation exception happens sometimes when working with plus-minus and minus-plus operators;
- Critical issue on closing worksheet fixed;
- Saving to .SM/.SMZ improved;
- Ar unit usage corrected for German localization;
- Icon for beta-extensions improved;
- Improvements for developers done;
- Experimental support for default output units system choosing implemented (WARNING: not all conversions available yet);
- Esperanto language added;
- Thai language added;
- Languages updated;
- Refactoring.
System requirements - Desktop (Windows):
Framework: .NET Framework 2.0
- Desktop (Linux):
Interface languages (37 languages) - [ARA] Arabic / العربي
- [BEL] Belarusian / Беларуская
- [BUL] Bulgarian / Български
- [CAT] Catalan / Català
- [CHS] Chinese (Simplified) / 简体中文
- [CHT] Chinese (Traditional) / 簡體中文
- [CPP] Portuguese (Brazil) / Brazil (Português)
- [CZE] Czech / Čeština
- [DAN] Danish / Dansk
- [DUT] Dutch / Nederlands
- [ENG] English / English
- [FAS] Persian / فارسی
- [FIN] Finnish / Suomi
- [FRE] French / Français
- [GER] German / Deutsch
- [GRE] Greek / Ελληνικά
- [HEB] Hebrew / עברית
- [HUN] Hungarian / Magyar
- [IND] Indonesian / Bahasa Indonesia
- [ITA] Italian / Italiano
- [JPN] Japanese / 日本語
- [KOR] Korean / 한국어
- [LAV] Latvian / Latviešu
- [LTH] Lithuanian / Lietuvių
- [NOR] Norwegian / Norsk
- [POL] Polish / Polski
- [POR] Portuguese / Português
- [RON] Romanian / Română
- [RUS] Russian / Русский
- [SCC] Serbian (Latin) / Srpski
- [SCR] Croatian / Hrvatski
- [SLK] Slovak / Slovenčina
- [SPA] Spanish / Español
- [SRP] Serbian (Cyrillic) / Српски
- [SWE] Swedish / Svenska
- [TUR] Turkish / Türkçe
- [UKR] Ukrainian / Українська
Free Download Tutorial SMath Studio tutorial by Bernard Liengme. SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
Introduction of the use of SMath Studio by Gilberto E. Urroz, Ph.D., P.E. Other files SMath Studio icons (  ) of all available sizes (16x16, 24x24, 32x32, 48x48, 64x64, 96x96, 128x128, 256x256) in PNG format. Edited by user 17 September 2015 18:08:44(UTC)
| Reason: Not specified
 7 users thanked Andrey Ivashov for this useful post.
on 17/09/2015(UTC), on 17/09/2015(UTC), on 17/09/2015(UTC), on 17/09/2015(UTC), on 17/09/2015(UTC), on 20/09/2015(UTC), on 16/01/2016(UTC)
Joined: 28/08/2013(UTC) Posts: 18  Was thanked: 2 time(s) in 2 post(s)
As always, thank you for your hard work. I'm looking forward to the latest changes.
I just updated to this version and I had the following plugins fail to load: -Checkbox Region -Combobox Region -Conditionally Formatted Label -Data Exchange -Modeller Region -XLSX Import/Export -Script Region -all of my custom plug-ins
I was able to resolve these errors immediately for everything except: -Script Region -all of my custom plug-ins
The 'error' that was being flagged for all of these plugins were: A strongly-named assembly is required. (Exception from HRESULT: 0x80131044)
Just so people have a 'heads up'
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,342   Location: Italy Was thanked: 1180 time(s) in 776 post(s)
Originally Posted by: 9_82abZ2  I just updated to this version and I had the following plugins fail to load: -Checkbox Region -Combobox Region -Conditionally Formatted Label -Data Exchange -Modeller Region -XLSX Import/Export I suppose it depends on the previous version of your SMath Studio (I've not noticed issues updating from the latest Nighlty Build). Simply uninstall them and download the most recent from the extensions Manager. If you still have issues let me know and I'll update the broken plugins. Originally Posted by: 9_82abZ2  -all of my custom plug-ins
The 'error' that was being flagged for all of these plugins were: A strongly-named assembly is required. (Exception from HRESULT: 0x80131044) It is because the plugins are compiled using not compatible APIs. Recompile your plugins using the new SMath Studio libraries.  Edited by user 17 September 2015 17:49:54(UTC)
Originally Posted by: 9_82abZ2  Just so people have a 'heads up' Your custom plug-ins must be recompiled in order to support this version of SMath Studio. As I see Script Region is a third-party plug-in with closed sources. If its sources will be published to https://smath.info/svn/public/plugins/ - then it will be possible to support new versions of the program automatically. But for now you should ask developers to recompile it directly. Best regards, Andrey Ivashov.
Originally Posted by: uncblue  I'm looking forward to the latest changes. Latest changes added to the post. Regards.
thanks a lot! I really love this wonderful software!
Originally Posted by: dysup  I really love this wonderful software! Glad to hear! Many thanks for your support!
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,131   Was thanked: 981 time(s) in 563 post(s)
About Script Region. I didn't have time to publish the source code. Now I need find it  and publish. |
As always, thank you Andrey. I really appreciate your efforts.
Joined: 05/03/2009(UTC) Posts: 411   Location: USA Was thanked: 12 time(s) in 11 post(s)
I see a cloud version (link) ... what happened to the portable version? Are there any plans to do a portable version again? That's what I like to use!
Excellent!  I like this software. Are you going to update the Pocket PC version for more features?
Thank you for the update and all the hard work!  I also still use Windows Mobile and would highly appreciate an update for it.
Joined: 28/08/2014(UTC) Posts: 19  Location: WA Was thanked: 1 time(s) in 1 post(s)
Back in Aug of 2014 I had downloaded a package SMath and Maxima. It just runs from the folder without having to install. It's very convenient and I take it with me everywhere. I would like to update to the newest version. Is there anyway I can keep it in this same easy to carry package?
