Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 127 time(s) in 82 post(s)
Dear All, I am a civil engineer, specialized in water resources engineering. My aim is to analyze 30 years of daily stream flow data in an Excel table with about 300 rows x 31 columns. The data table contains negative values and strings which I have to discard first. Then I want to create a column vector of data for further analysis. The Smath program shown below gives the result, but takes a long time (about 50 seconds- see image). As I build up the program for further analysis, the time grows up to even 5 minutes or more. However, my Mathcad 15 program yields the result almost immediately. Can anyone help to resolve this please? Thanks in advance. ndtma Edited by user 29 April 2015 09:56:51(UTC)
| Reason: To attach Excel file File Attachment(s): ndtma attached the following image(s): |
Hello ndtma I attach my proposal (approx. 25s on my notebook). The first part takes advantage from how are built matrices in SMath. The slower part is the 2nd (as for now I don't have ideas on how to improve this part). [edit] please note that the first part is not strictly required, anyway seems to me (?) that there's a small speed improvement using a vector instead of the linear indexing on the matrix Edited by user 29 April 2015 11:43:31(UTC)
| Reason: Not specified File Attachment(s): Davide Carpi attached the following image(s): |
Hello Davide
Thanks for your valuable proposal, and I am awaiting more improvements.
Best Regards ndtma |
12s average (not immediate, however faster than the previous solution) File Attachment(s): Davide Carpi attached the following image(s): |
Hello Davide
Thanks for the second improvement.
I was faced with a similar problem of a slow function (in fact EXCEL interop call). I could not speed up the function so I have created if() loops that will run the function only when input has changed. This makes sure that when workbook automatically recalculates it will not get "stuck" on a slow function unless necessary. A sample is attached. In the workbook c:a+b is an example function, while a+b is input. Hope that helps
