I have odd behavior with assigning values to my output parameters of my function. If I run the function the first times the variables seem to be assigned their respective values. However when I refresh it tells me that the variables are not defined. If I start to type the variable I see that is infact assigned the values, however again if I enter the variable then refresh it says it is not defined.
