Joined: 06/04/2010(UTC) Posts: 1 Location: Los Angeles, CA
Just started using the beta program. This is a wonderful project and is very helpful. Units conversion is a major reason for my wanting to use the software. Thanks very much for working on this.
I discovered a problem with the way the volumetric unit gallons (gal) are handled. It should be 3.785e10^-3 m^3, but SMath build 3728 derives this as 3785 m^3, a factor of 10^6 different.
Thanks, Dave S.
Joined: 09/01/2010(UTC) Posts: 102 Location: Oregon, USA Was thanked: 5 time(s) in 5 post(s)
dnsalyer wrote:Just started using the beta program. This is a wonderful project and is very helpful. Units conversion is a major reason for my wanting to use the software. Thanks very much for working on this.
Thanks, Dave S. Yes, I also confirm that the conversion performed by Smath is incorrect here; 1 gallon should equal 0.00378541178 meters cubed. Will Edited by user 12 May 2010 22:12:49(UTC)
Will Massie Mechanical Engineer Oregon, USA |
Thank you. Will fix today.
Fixed.
