Hello Andrey, I would suggest to change the assignment operator ( := ) behavior. Just look at this, please: x←5+6x=5 WRONG!This is because we can type something like this: x:5[SPACE]+6This can be hard to trace. Fortunately, we can put the mouse on the region and see the probem, if the expression is simple. If the expression is a bit more complicated we might not see where the problem was. Just a single careless [SPACE] might make a problem. I suggest (if possible) not to allow inserting anything when, say, this is the case: Inserting any operator, or anything else should be simply disabled. Regards, Radovan Edited by user 16 March 2010 22:18:53(UTC)
