hi
i was trying to invert a matrix with smath winxp 2010-feb10 version. It gives me an error that "matrix is noninvertible (determinant equals zero)". the determinant is not zero, i have checked. i have tried the M^-1 and invert(M) too. but gives the same error.
if i do this, then it works, calculates the result: M:=... M^-1= RESULT
if I do this, then it does not work: M:=... M2:=M^-1 M2= ERROR
M=1/sqrt(2)*mat(1,-1,0,0,0,0,1,-1,1,1,0,0,0,0,1,1,4,4) det(M)=-1 so it is not zero if i change the matrix, to get a different determinant, not -1, then it wors.
Hello. I can't reproduce this error with my matrices: Could you please send your full example to support[at]smath[dot].info? Best regards, Andrey Ivashov.
OK, I see now, thanks. Will check in 5 hrs.
Figured out that this error was in previous versions of SMath Studio as well when trying to evaluate symbolically: (1/sqrt(2)*mat(1;-1;0;0;0;0;1;-1;1;1;0;0;0;0;1;1;4;4))^{-1}—#
Starting work to fix it.
Here is modified version of SyLib.dll file for SMath Studio 0.87 where this bug fixed: http://smath.info/?file=739022 (just unpack it and replace original SyLib.dll from Program Files/SMath/SMath Studio folder). You can use it till next version of the program will be released. Regards. Edited by user 15 February 2010 07:20:05(UTC)
| Reason: Not specified
