Offline Paolo83
#1 Posted : 21 January 2010 15:13:07(UTC)
Paolo83
Hallo!
I have a little problem...
I imput an equantion like letters (that it are specitied before in the program)
(ex. A:=b*c)
and when I ask the results the program say that the number is to large, but,
if I write the same equation without the variable definition, just to have the
number directly (ex. b*c=), the program works...
tank you!
Offline Andrey Ivashov
#2 Posted : 21 January 2010 18:45:15(UTC)
Hello Paolo.
Please, can you provide more details about this problem? F.e. file that you work with.
Offline Paolo83
#3 Posted : 21 January 2010 20:50:12(UTC)
Paolo83
Yes! if you want I can give you the file, but I don't have your mail.
#4 Posted : 21 January 2010 21:27:10(UTC)
E-mail you can find in the About Dialog of SMath Studio, it looks like: support [at] smath [dot] info but much more pretty Good
Offline Paolo83
#5 Posted : 21 January 2010 22:02:43(UTC)
Paolo83
I have send an e-mail to you just now.
Thanks!
#6 Posted : 22 January 2010 16:04:34(UTC)
Thank you. I've checked your file and figured out the problem.
This happens because in L0 large and complex expression stored. To fix an error you should just use eval(..) function for L0 before using it. Here you can find more about eval(..) function:
- http://smath.info/wiki/(S(3pgwxdbc0eaary552kcqsr3o))/eval.ashx
- http://en.smath.info/forum/default.aspx?g=posts&m=1030#post1030
As a solution for your problem I recommend to go this way:
L0←eval(if(L0x>L0y;L0x;L0y))
Offline Paolo83
#7 Posted : 22 January 2010 16:49:16(UTC)
Paolo83
Ah! OK!! take you very much! ^_^
Similar Topics
Arcade Games Improve Reflexes And Muscle Memory -gameeurope.com (Samples)
by te86ll001 08/04/2022 04:52:11(UTC)
Arcade Games Improve Reflexes And Muscle Memory (Features announcements)
by hunian161 06/04/2022 07:36:33(UTC)
Calculation Memory, Tube Heat Exchanger and Compact Shell (Samples)
by Valentino 03/08/2021 12:56:17(UTC)
Memory problem (Bugs & Problems)
by mkraska 01/07/2012 16:25:23(UTC)
