Offline LordMike
#1 Posted : 27 October 2009 16:11:49(UTC)
LordMike
Hey,
I might have a bug in the sine function. It's minorily out of course...
My calculator gives
sin(0) -> 0
sin(pi) -> 0
sin(2 pi) -> 0
Options are set to radians.
Offline LordMike
#2 Posted : 27 October 2009 16:27:01(UTC)
LordMike
I have found a significant reason for this 'error'...
It seams, that smath doesn't take into account, PI, as symbol behind the scenes.
It calculates it as a decimal value with 'only' (I think) 15 decimals...
Please make PI a symbol until absolutely necessary to show as a decimal Good
Offline omorr
#3 Posted : 27 October 2009 16:34:35(UTC)
omorr
Serbia
If you use symbolic SMath engine, here is the result:
sin(π)—0
sin(2*π)—sin(2*π)
EDIT:On the other hand there is no decimal treshold in SMath where the small numbers should be represented as zero.
Edited by user 27 October 2009 16:40:32(UTC)  | Reason: Not specified
Offline LordMike
#4 Posted : 27 October 2009 16:41:26(UTC)
LordMike
How does one use this symbolic engine?
Offline omorr
#5 Posted : 27 October 2009 16:44:43(UTC)
omorr
Serbia
Instead of regular equal to (numeric) press symbolic equal to (right arrow on the Arithmetic palette) or CTRL+. as shortcut.
Offline LordMike
#6 Posted : 27 October 2009 16:51:21(UTC)
LordMike
Like this?:
Offline omorr
#7 Posted : 27 October 2009 16:55:29(UTC)
omorr
Serbia
LordMike wrote:
Like this?:
Yes, you are right. The symbolic result will give symbols and numbers as fractions, numeric result will give you floats (with fixed decimal point, or scientific format - number of decimals can be set by Tools=>Options=>Decimal places)
EDIT:some functions (like solve) will give you only numerical values (you will not have PI in this case). Therefor, you will not have the "symbolic" answer. The same is with integration f.e.
Edited by user 27 October 2009 16:59:21(UTC)  | Reason: Not specified
Offline LordMike
#8 Posted : 27 October 2009 17:00:50(UTC)
LordMike
We do then agree, that working with PI as a number, is stupid.
F.ex, when setting it into the sine function, as such: sin(pi).
When I then do this:
I'd prefer if it showed 0 both places. Given the fact that behind the scenes, it *should* work symbolically.
EDIT: (omorr edited)
Hmm.. That's not practical. Seriously...
Offline omorr
#9 Posted : 27 October 2009 17:12:08(UTC)
omorr
Serbia
I agree Mike, but at the moment SMath is working this way. Andrey is doing his best to improve it. Xcas as a symbolic engine and plugin will make solving equations and integration real symbolically. Maybe some other symbolic engines as plugins will be included in the future.
EDIT: Hmm... Did I make a mistake - it is different than yours?
solve(-sin(x)≡0;x;0;2*π)=mat(0;3,142;2;1)
sin(el(solve(-sin(x)≡0;x;0;2*π);1))=0
sin(el(solve(-sin(x)≡0;x;0;2*π);2))=-5,787*10^{-12}
or setting 10 decimal places
sin(el(solve(-sin(x)≡0;x;0;2*π);2))=3,2310851043*10^{-15}
Edited by user 27 October 2009 17:26:08(UTC)  | Reason: Not specified
Offline LordMike
#10 Posted : 27 October 2009 18:08:53(UTC)
LordMike
I had 3 decimal places... Dunno what you had on the first one ...
EDIT:
10 decimal spaces:
-1.0206823939*10^{-11}
Edited by user 27 October 2009 18:10:23(UTC)  | Reason: Not specified
Offline omorr
#11 Posted : 27 October 2009 18:38:32(UTC)
omorr
Serbia
EDIT:
10 decimal spaces:
Have no explanation about this, sorry ????
EDIT: I think I found it. It seems the release v0.85_3531 (the official one) gives your result. I think that some fixes are applied in the meantime. My results are from the recent ones v0.85_3545 and v0.85_3578.Alpha.
Edited by user 27 October 2009 19:06:27(UTC)  | Reason: Not specified
Offline Andrey Ivashov
#12 Posted : 27 October 2009 19:02:47(UTC)
Will check at home.
Offline dm
#13 Posted : 07 April 2010 21:21:59(UTC)
dm
In stable version 0.87 I still have this:
degree setting:
a=0
b=90
cos a =1
cos b =2,9371118168*10^{-14}
radians seems correct.
Thanks in advance.
