Offline RegRetired
#1 Posted : 09 May 2024 08:35:48(UTC)
RegRetired
Help would be appreciated. I cannot make a chain of if-else statements equal to the cases formalism. What am I missing. I have tried the less than or equal only in the cases formalism. That didn't work either. The if-else results are correct, the cases formalism is not correct.
IF ELSE VERSUS CASES FORMALISM.sm (13kb) downloaded 4 time(s).
Thanks for any help.
Reg
Reg Curry
Loveland, CO
Offline RegRetired
#2 Posted : 09 May 2024 08:43:15(UTC)
RegRetired
Oops sorry. I had errors in my formulas. Here is the corrected version where the two formalisms do agree.
IF ELSE VERSUS CASES FORMALISM.sm (13kb) downloaded 6 time(s).
Sorry Blush
Reg Curry
Loveland, CO
#3 Posted : 09 May 2024 22:09:52(UTC)
No problem, when possible, better ask.
I would point out that currently you can avoid the nested if/else and convert it in if/else if/else (if you wish), simply adding more arguments. As side note if you delete an argument from the default if/else, you'll get an if without else.
IF ELSE VERSUS CASES FORMALISM(2).sm (17kb) downloaded 14 time(s).
Also, since the topic is about if/else vs cases, I would like to highlight that cases has a different coding approach to evaluate in some situations where if/else is not allowed to; this feature comes at the cost that you shouldn't make assignments ( : ) inside its arguments, while in if/else you can safely build block of codes inside it using the line function (see here and here for examples).
Edited by user 10 May 2024 10:15:37(UTC)  | Reason: small clarification
Offline RegRetired
#4 Posted : 10 May 2024 07:02:59(UTC)
RegRetired
Davide,
Thanks much. Very helpful as always.
Reg
Reg Curry
Loveland, CO
