Joined: 05/05/2023(UTC) Posts: 7 Location: Milan Was thanked: 1 time(s) in 1 post(s)
Hi I've got a problem with a 3D plot function. The function is very simple but i'm not able to find the correct syntax for plot it. Someone can kindly help me with some advising? Thancks in advance, i attacched below the Smath reference file where i had higlighted with an arrow the function. Azioni_Sismiche_Silo_D1101.sm (1,209kb) downloaded 7 time(s).
Thancks so much for your answer!!!! I'm very gratefull!
Very easy to get the two circles ... one being shifted. Tip about X_Y plot ... as soon as you open, give a title. Next manipulation, click on title. That technique will save from freaking X,Y ranges. Jean.
Originally Posted by: Ale_Biaso I've got a problem with a 3D plot function. The document from Martin does not work for me. At this point of the project, if you can attach the matrix, I may try to render the gray image in RGB. I have the RGB mapping codes associated with the vectorise code.Not so sure ... your matrix is huge 360 cols ! Jean
