Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
Hi, I came across a problem in the use of findrows() function when applied to a nested array. The nested array is the result of a Slope Stability Analysis example. Sufficient explanatory notes included. However, I was able to get required values by some manipulations as shown. Is there a better method ? Findrows Problem.sm (20kb) downloaded 6 time(s). |
1 user thanked PompelmoTell for this useful post.
Joined: 15/04/2012(UTC) Posts: 1,987 Was thanked: 1124 time(s) in 721 post(s)
I'd perhaps just join the columns by augment() and then apply findrows(). Findrows Problem_Kr.sm (24kb) downloaded 5 time(s). |
2 users thanked mkraska for this useful post.
on 10/09/2023(UTC), on 11/09/2023(UTC)
Hello Martin and sergio, Thank you both for the helpful replies |
Hi, A revised program, based on mkraska's solution. Findrows Solved.sm (16kb) downloaded 9 time(s).Edited by user 11 September 2023 14:06:08(UTC)
1 user thanked ndtma for this useful post.
