Rank: Advanced Member Groups: Registered, Advanced Member Joined: 06/04/2023(UTC) Posts: 339 Was thanked: 26 time(s) in 25 post(s)
My students were building a multifocal ellipse and... almost went crazy. My ellipse is correct, but the student's is incorrect. Although the formulas are the same. Can you guess where the error is and whether it is necessary to modify SMath so that such an error is visible? Do you know more some examples? Ellipse4.sm (12kb) downloaded 10 time(s).Edited by moderator 08 September 2023 12:53:02(UTC)
| Reason: marked as SOLVED (not a bug)
In fact only apparently the written formula is the same but in the first case "S" is outside the summation while in the second case it is inside the summation. You can verify this by copying and pasting the two formulas into a text editor.
1 user thanked PompelmoTell for this useful post.
Joined: 23/03/2016(UTC) Posts: 277 Was thanked: 91 time(s) in 57 post(s)
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1329 time(s) in 875 post(s)
Originally Posted by: PompelmoTell In fact only apparently the written formula is the same but in the first case "S" is outside the summation while in the second case it is inside the summation. You can verify this by copying and pasting the two formulas into a text editor.
sergio You can also select/double-click the sum symbol to check what belongs to it. |
on 07/09/2023(UTC), on 07/09/2023(UTC)
Joined: 10/12/2009(UTC) Posts: 248 Location: Cali, Colombia Was thanked: 87 time(s) in 66 post(s)
The problem is that in the first Ellipse(x,y) definition, variable S is outside Sum function, but in the definition of your students is inside: Your definition: Ellipse(x,y):sum(sqrt((x-el(X.F,i))^2+(y-el(Y.F,i))^2),i,1,N)-S Student´s definition: Ellipse(x,y):sum(sqrt((x-el(X.F,i))^2+(y-el(Y.F,i))^2)-S,i,1,N) Maybe, this explicit form is most clear for students: Edited by user 07 September 2023 18:06:56(UTC)
| Reason: Not specified
1 user thanked oscampo for this useful post.
Better so
1 user thanked OchkovVF for this useful post.
It if Mathcad 15 1 ln(x) 2 ln*x - why not
