Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
Hi, When working on a slope stability analysis problem, I had to use an intermediate result which may be a nested matrix or just a simple matrix. This intermediate result depends on the 2D cordinates (x,y) of the center of the assumed slip circle and other factors. However, this intermediate result cannot be used automatically to continue as I have to manually input these values. Details are given in the sm file and image. Kindly help me. Nested Array_Problem2.sm (19kb) downloaded 5 time(s).Edited by user 31 July 2023 12:13:01(UTC)
Originally Posted by: Razonar Hi Amarasekera. Hope this helps. Hi Alvaro! This is what I wanted. Thank you very much |
Originally Posted by: ndtma Originally Posted by: Razonar [url=/forum/yaf_postsm82124_Nested-Matrix-Problem.aspx#post82124][/url]Hi Amarasekera. Hope this helps. Hi Alvaro. This is what I wanted. Your example slightly revised. It is possible, the slip circle may cut the slope profile at two locations and hence two values. Otherwise, one value. Your example gave me a golden opportunity to proceed. Thank you again Nested Array_Corrected.sm (22kb) downloaded 10 time(s).Edited by user 31 July 2023 15:11:24(UTC)
Originally Posted by: ndtma Hi Alvaro. This is what I wanted. Your example slightly revised. It is possible, the slip circle may cut the slope profile at two locations and hence two values. Otherwise, one value.
Image of ACAD drawing, with slip circle cutting at two points on the two horizontal lines. Otherwise, cuts at one point on one horizontal line and the other on slope line. For demonstration of first case. Edited by user 01 August 2023 16:23:49(UTC)
