Offline JReg
#1 Posted : 25 June 2023 02:01:55(UTC)
JReg
The attached files show the same calculation plotted in both the SMATH XY graph and a ZEDGRAPH. The lines are not as smooth in the ZEDGRAPH. Is this a quirk of ZEDGRAPH, or do I have some setting incorrect.
Both .sm and .pdf files are provided. The scale of the pdf must be enlarged to see the difference in the two graphs.
Thanks,
Reg
Reg Curry
Loveland, CO
#2 Posted : 25 June 2023 03:51:15(UTC)
Originally Posted by: JReg Go to Quoted Post
The attached files show the same calculation plotted in both the SMATH XY graph and a ZEDGRAPH. The lines are not as smooth in the ZEDGRAPH.Is this a quirk of ZEDGRAPH, or do I have some setting incorrect.
You plot the same data set on different plot ranges.
Make the two graphs consistent, for immediate comparison.
Offline JReg
#3 Posted : 25 June 2023 05:02:48(UTC)
JReg
Try these.
NOTE: Arial 8pt in XY does not look the same in ZEDGRAPH.No
Reg Curry
Loveland, CO
Offline overlord
#4 Posted : 25 June 2023 05:12:43(UTC)
Turkey
Sorry for the huge screenshot.
Its due to line and symbol settings of traces.
Changing them will provide smoother line.
GRAPH COMPARISONS_smooth.sm (40kb) downloaded 17 time(s).
Click to enlarge
Offline JReg
#5 Posted : 25 June 2023 05:35:47(UTC)
JReg
Thanks much! That helps. Good
Reg Curry
Loveland, CO
#6 Posted : 25 June 2023 13:40:06(UTC)
Your X_Y plot was spoiled.
If you click in the graph region and move the pointer,
it freaks the X & Y ranging ... your delivered 1rst attachment.
Zedgraph is more traditional of Bode plots.
GRAPH COMPARISONS_smooth.sm (40kb) downloaded 11 time(s).
