Rank: Advanced Member Groups: Registered, Advanced Member Joined: 06/04/2023(UTC) Posts: 348 Was thanked: 28 time(s) in 27 post(s)
I cannot use the roots function and must use one old good simple method by Newton. What can you say about it? Newton-Eng.docx (1,106kb) downloaded 29 time(s).Edited by user 08 April 2023 22:12:41(UTC)
| Reason: Not specified
1 user thanked OchkovVF for this useful post.
Very nice. I had problems when reproducing your 2D version. Depending on initial guess I got errors "requested matrix element does not exist". The situation seemed to improve a little by pre-allocating the vectors X and Y yet it didn't become really robust. So instead of assigning to j+1 elements I used augment() to add new points to the iteration history. This is the original version: Newton2D.sm (22kb) downloaded 10 time(s).And this is the modified version. Newton2Da.sm (20kb) downloaded 14 time(s). |
Originally Posted by: Jean Giraud ... can't find 2nd root 2nd root confirmed exact. Solve(f,q,x0,x1,TOL) Copy.sm (163kb) downloaded 7 time(s).
Joined: 23/07/2013(UTC) Posts: 1,129 Was thanked: 510 time(s) in 340 post(s)
Tried to solve your functions with al_nleqsolve(). Regards Newton.sm (14kb) downloaded 12 time(s).
Joined: 28/08/2014(UTC) Posts: 1,368 Was thanked: 829 time(s) in 525 post(s)
Another way, keeping the mathematical formulation and the iteration algorithm separate. As here. Newton2Da.sm (14kb) downloaded 11 time(s).Best regards. Alvaro. Edited by user 10 April 2023 00:27:45(UTC)
Thanks Alvaro, added to my next Samples visit. Take care ... Jean
Originally Posted by: OchkovVF I cannot use the roots function Actually, you can. Regards
Originally Posted by: OchkovVF I cannot use the roots function and must use one old good simple method by Newton. What can you say about it? An old vintage in Smath ... two examples. Take care Valery ... Jean. Solve_roost f1(x,y). f2(x,y).sm (28kb) downloaded 10 time(s).
Originally Posted by: Razonar From my future article Если уравнений не два, а три, то матрица Якоби будет состоять из трёх строк и трёх столбцов. При этом графически отображать решение придётся не двумя кривыми, а тремя поверхностями на 3D-графике, причём их взаимное пересечение и будет отмечать решение (задание читателю). Слабо!
