Offline Javier Ochoa
#1 Posted : 29 March 2023 20:41:21(UTC)
Javier Ochoa
Rank: Member
Argentina
I installed Smath Studio from the AUR repository, I am using Arch and the installation went fine.
I am reading the document GraficasBasicas2012.pdf, which I downloaded from the Wiki Tutorials.
The problem is that the function augment(1,2,3) works different under Linux, and I cannot figure out how to make a simple graphic as the one in the adjointed file.
graficos_prueba.sm (10kb) downloaded 10 time(s).
Maybe someone could help me, regards.
#2 Posted : 29 March 2023 21:59:11(UTC)
Javier Ochoa
Rank: Member
Argentina
In the Tools->Options Section I could change the semicolon <;> and now I use the comma (,) as separator. Now I can use the function augment with comma (,) but the graphic function is still not working.
I wonder whether someone can give me a hint.
#3 Posted : 30 March 2023 14:09:11(UTC)
... fast, perfect meshing 'x'.
#4 Posted : 30 March 2023 16:21:48(UTC)
Javier Ochoa
Rank: Member
Argentina
Hi Jean,
Tank you for the post, he problem was solved using the pallete. I will mark as solved.
#5 Posted : 30 March 2023 17:34:39(UTC)
Originally Posted by: Javier Ochoa Go to Quoted Post
Hi Jean,
Tank you for the post, he problem was solved using the palette.
NO Javier, NOT solved.
Your 'x' is improperly meshed.
#6 Posted : 30 March 2023 18:16:30(UTC)
Javier Ochoa
Rank: Member
Argentina
Hi Jean,
I can reproduce your example without any problem, I cannot understand where the parameters H,N and L are defined. Also, you defined a function xd and used to evaluate x. Why I cannot use range?.
I suppose that is there an useful explanation for this, which I am curious about it. Maybe, you can give me some hint?
#7 Posted : 30 March 2023 19:09:12(UTC)
Hi Jean,
[L,H,N] are defined in x:= xd(L,H,N)
Why I cannot use range ?.
If you use range, 'x' will start -pi
but will never exactly terminate +pi
unless N in range is 15 decimals ... totally foolish.
Your graph does not terminate +pi.
xd discretizer will populate exactly any 'N' ± pi.
#8 Posted : 30 March 2023 21:28:21(UTC)
... complete algo style, one of my preferred.
Javier.sm (11kb) downloaded 9 time(s).
#9 Posted : 30 March 2023 22:22:54(UTC)
Javier Ochoa
Rank: Member
Argentina
Hi Jean,
I am greatly surprised with your answer.
I will take care of this lesson in future calculations.
Thanks in advance,
Offline overlord
#10 Posted : 31 March 2023 03:49:26(UTC)
Turkey
If your purpose is plotting a range, this is the way.
This is most suitable for your type of functions.
No mumbo jumbo, no algorithm, no unnecessary coding.
Only pure simple if block.
graficos_prueba1.sm (12kb) downloaded 5 time(s).
on 31/03/2023(UTC)
#11 Posted : 31 March 2023 15:40:31(UTC)
Javier Ochoa
Rank: Member
Argentina
Hi Overlord,
I very appreciate your thoughts, the graphics looks pretty good.
Kind regards
#12 Posted : 31 March 2023 16:55:57(UTC)
Hi Jean,
Thanks in advance,
The all thing is to complete a project, mostly export.
See the missing regions ...
Please, don't hesitate ... Jean.
Javier More.sm (10kb) downloaded 10 time(s).
#13 Posted : 31 March 2023 17:05:02(UTC)
Javier Ochoa
Rank: Member
Argentina
Hi Jean,
This file is showing the origin of some missing parameters, like H,L,N, thank you for this worksheet.
I have a BSc in chemical engineering and a PhD in Industrial Chemistry, I also work in a biotechnology institute since 2003.
Maybe, this is why I was asking so many questions.
Kind regards,
#14 Posted : 01 April 2023 02:27:42(UTC)
You are not used yet to Smath algorithmic construction
Eager to assist your ChemEng projects.
#15 Posted : 01 April 2023 16:20:34(UTC)
To fully understand the command line algorithmic construction,
revisit this 4 examples document. Cheers ... Jean
Solve(f,q,x0,x1,TOL).sm (55kb) downloaded 9 time(s).
Guest (2)
