Good day everyone, I am building a Hertzian stress calculator and got stuck at the step where I calculate the k value for a particular B/A reationship. Any help will be appriciated contact stress calc.sm (23kb) downloaded 27 time(s).
We also know than K will always be in the range (0,1) The equations presented above is obtained from the book Advanced Mechanics of Materials by Boresi Et al
In case of these functions, al_nleqsolve() can be the answer. No other solver is capable other than al_nleqsolve(). k' should be under line, otherwise not solveable. Here is your function solved. Regards contact stress calc_1.sm (29kb) downloaded 28 time(s).
3 users thanked overlord for this useful post.
on 21/10/2022(UTC), on 21/10/2022(UTC), on 24/10/2022(UTC)
Was thanked: 9 time(s) in 9 post(s)
Originally Posted by: Jean Giraud Your original document is circular and indigestible. From un-sourced [K,E] and arbitrary datum ... solve. This sample is not appropriate. As you have said, it is only solvable when K and E already given. roots() can't solve without K and E given or calculated separately. And you can't calculate K and E while not knowing what k is. Your sample is not what OP wants. He means to solve that complicated Q function. Without any parameter or variable of K and E are pre-given. Edited by user 24 October 2022 02:02:33(UTC)
| Reason: Not specified
2 users thanked overlord for this useful post.
on 24/10/2022(UTC), on 24/10/2022(UTC)
With elliptic integrals from GSL and Cephes library. Edited by user 24 October 2022 15:54:50(UTC)
on 24/10/2022(UTC), on 25/10/2022(UTC), on 26/10/2022(UTC)
Joined: 10/12/2009(UTC) Posts: 248 Location: Cali, Colombia Was thanked: 87 time(s) in 66 post(s)
Originally Posted by: ryno Good day everyone, I am building a Hertzian stress calculator and got stuck at the step where I calculate the k value for a particular B/A reationship. Any help will be appriciated contact stress calc.sm (23kb) downloaded 27 time(s). Solving by the old bisection method: contact stress calc_by_bisection.sm (27kb) downloaded 6 time(s).
2 users thanked oscampo for this useful post.
on 25/10/2022(UTC), on 25/10/2022(UTC), on 25/10/2022(UTC)
Originally Posted by: overlord Solving with a custom algorithm. Very elegant!
