Joined: 30/08/2009(UTC) Posts: 52 Location: Australia
Not to sure how it is coded, but would it be possible to explicitly state the output variable within a function. For instance func( a,b):=some complicated stuff which ends up in M M= Edited by moderator 21 September 2009 05:05:39(UTC)
| Reason: Smile removed
Not sure I understand. Please, post detailed explanation, maybe I'll implement it.
http://smath.info/wiki/G...unday_insert_problem.zipfor example. The procedure to insert a row works, but the function doesn't because you can't explixitly return the answer. Something like ans:=B would be the way i'd expect to do it, where ans is a reserved word like in Matlab
Greg Locock wrote:http://smath.info/wiki/GetFile.aspx?File=gregpics%5csunday_insert_problem.zip
This is, actually, the possibility to make Mathcad-like multiline functions with "line" (extension of SMath programing capability). It is on my "wishlist" as well. I really do not have the slightest idea how complicated could that be to implement in SMath, considering differences between SMath and Mathcad. As far as I know (hope I am right) the only way to define a function in more then one line (just visually) is with "if": func(x)←if(x≤5;5;x)func(2)=5 func(10)=10Regards, Radovan Edited by user 21 September 2009 18:23:37(UTC)
other syntax suggestions, these would go as the last line in a multiline function I don't really have a preference, although B= is probably a bit weird. Edited by user 21 September 2009 18:43:02(UTC)
| Reason: smiley
