SMath Studio Forum
Questions
Rounding Values in Vectors - User Function
Joined: 02/04/2018(UTC) Posts: 135 Was thanked: 22 time(s) in 19 post(s)
Version: 0.99 (Build: 7921) The rounding function concept for a vector seems to work fine, but I am having trouble with a function that works on a vector containing multiple vectors. Any ideas on how to make this work? Rounding Values in Vectors Function Concepts.sm (18kb) downloaded 12 time(s).Edited by user 26 April 2022 00:31:32(UTC)
| Reason: Not specified
Joined: 23/07/2013(UTC) Posts: 1,129 Was thanked: 510 time(s) in 340 post(s)
Originally Posted by: wb.c The rounding function concept for a vector seems to work fine, but I am having trouble with a function that works on a vector containing multiple vectors. Any ideas on how to make this work? You can use recursive for that. You have to also check if rounded row is a vector. It can work with both vector and nested vector. Here is your code revised. Regards PS: MarB's solution with Razonar's addition is better actually. I would use that instead of mine, more elegant. My version is just a brute algorithm. Rounding Values in Vectors Function Concepts.sm (24kb) downloaded 2 time(s). rounding_matrices.sm (11kb) downloaded 21 time(s).Edited by user 22 April 2022 23:37:49(UTC)
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 127 time(s) in 82 post(s)
Another approach |
Above method will not work if the nested arrays are of different sizes. Following method will work for any nested array. |
1 user thanked ndtma for this useful post.
Joined: 15/07/2010(UTC) Posts: 437 Location: Beer-Sheva Was thanked: 520 time(s) in 288 post(s)
Almost the same Variant.sm (9kb) downloaded 7 time(s).
2 users thanked Ber7 for this useful post.
on 21/04/2022(UTC), on 21/04/2022(UTC)
Code revised to solve not just vectors but matrices too. Now very complicated matrices can be rounded. Regards PS: MarB's solution with Razonar's addition is better actually. I would use that instead of mine, more elegant. My version is just a brute algorithm. rounding_matrices.sm (11kb) downloaded 21 time(s).Edited by user 22 April 2022 23:38:21(UTC)
4 users thanked overlord for this useful post.
on 21/04/2022(UTC), on 21/04/2022(UTC), on 21/04/2022(UTC), on 22/04/2022(UTC)
Great ideas everyone, thanks for the input and improvements.
Good idea to always start code native Smath ... given user extended.
You can also shorten function like this.
A very short way is to use recursion: roundM.sm (10kb) downloaded 7 time(s).Edited by user 22 April 2022 13:56:32(UTC)
4 users thanked MarB for this useful post.
on 22/04/2022(UTC), on 22/04/2022(UTC), on 22/04/2022(UTC), on 22/04/2022(UTC)
Up to this point, proposals round nested vectors. Dealing with big numbers is also available. 123456789123456789 ... 987654321987654321 123000000000000000 typical
Originally Posted by: MarB A very short way is to use recursion. This is just magnificent. Two heads are better than one. I couldn't hit off how to do it with vectorize. Kudos
Originally Posted by: MarB A very short way is to use recursion:
Wonderful!
Joined: 28/08/2014(UTC) Posts: 1,370 Was thanked: 829 time(s) in 525 post(s)
Originally Posted by: MarB A very short way is to use recursion ...
Brillant solution. Adding eval to the SMath's round enables symbolic evaluations too. Best regards. Alvaro.
2 users thanked mkraska for this useful post.
on 23/04/2022(UTC), on 23/04/2022(UTC)
... twin vectors from function Advanced Engineering applications.
Originally Posted by: mkraska Minimalistic solution for Maximalists. Sometimes I really wish I could use Maxima plugin under linux.
Originally Posted by: overlord Originally Posted by: mkraska Minimalistic solution for Maximalists. Sometimes I really wish I could use Maxima plugin under linux. It is on my todo list and I think it is possible, but currently priority is on another project which also involves using Maxima and is entirely open source: https://github.com/mkraska/meclib |
SMath Studio Forum
Questions
