Offline hpf_br
#1 Posted : 19 November 2013 20:15:38(UTC)
hpf_br
Rank: Member
Brazil
Why it doesn't work on SMath ? It works fine on MathCAD 14.
Matrix element
hpf_br attached the following image(s):
Offline IVR
#2 Posted : 20 November 2013 00:49:17(UTC)
IVR
Was thanked: 3 time(s) in 2 post(s)
1. Read program's documentation
2. Use for loop
Offline mb10
#3 Posted : 20 November 2013 14:16:34(UTC)
mb10
Rank: Member
Was thanked: 9 time(s) in 5 post(s)
Offline hpf_br
#4 Posted : 20 November 2013 14:22:20(UTC)
hpf_br
Rank: Member
Brazil
I didn't find anything about calculating with arrays in this way. And it's not necessary to use loop as i won't test anything. In addition to typical linear algebra calculations, arrays in Mathcad are useful for performing calculations repeatedly over a range of values. See in the first image another SMath example and in the 2nd image how Mathcad does it:
Edited by user 20 November 2013 14:35:48(UTC)  | Reason: Not specified
Offline mkraska
#5 Posted : 20 November 2013 19:03:09(UTC)
mkraska
SMath cannot handle vector-valued indices in expressions (AKA "range variables" in Mathcad). Therefore you MUST use loops or you rely on functions from 3rd party plugins like matlab c++ library by uni or Maxima, where nearly all functions can be applied to vectors (without indices). Your example reveals that you might not be aware of the difference between text indices and adress- or array indices.
Most of the tutorials for SMath adress this issue, as this is a very common pitfall for newbies.
File Attachment(s):
Section matrix elementwise.sm (36kb) downloaded 126 time(s).
Offline hpf_br
#6 Posted : 21 November 2013 19:13:51(UTC)
hpf_br
Rank: Member
Brazil
My intention was to reproduce in SMath Studio operations with vectors as in Mathcad. I understand you, but on Mathcad there is no problem to do like that. Besides, only now I'm working with SMath, and I also learning on how to use the program.
Similar Topics
Assign unit to a matrix element within a foor loop (Questions)
by kratikus 10/06/2022 16:52:21(UTC)
slow extraction of matrix elements (Questions)
by Jopi 14/09/2021 12:13:45(UTC)
Using Matrix element in Boolean evaluation (Bugs & Problems)
by alyles 22/11/2017 21:06:57(UTC)
Cannot get matrix element (Bugs & Problems)
by MK001 02/05/2015 21:02:38(UTC)
Vector & matrix element magnitudes (Questions)
by FrugalTPH 18/12/2012 15:16:17(UTC)
Feature Req: Matrix Elements as a Group of Individuals (Project discussion)
by Guest 17/11/2010 03:36:28(UTC)
