Offline Jopi
#1 Posted : 14 September 2021 12:13:45(UTC)
Jopi
Rank: Member
Hallo,
Thanks to PTC's weird policy, I'm now trying to switch completely to Smath and have started rebuilding my main sheets.
Now I'm running into a problem here that I can't solve:
I build a matrix in half a second, but I can't display it. Even displaying a single element doesn't finish unless I shrink the matrix w.
The optimization of all equations is set to "numerical", the matrix elements should then be ready calculated, right? Does anyone know such a behavior?
The complete sm file and the data for it will come tomorrow.
Best regards,
Johannes
Extract Matrix element.png (1,023kb) downloaded 40 time(s).
Edited by user 14 September 2021 14:45:51(UTC)  | Reason: Not specified
Offline Jopi
#2 Posted : 14 September 2021 14:43:02(UTC)
Jopi
Rank: Member
Putting eval() around the matrix definition solved this.
But what is then the setting "numerical" good for?
#3 Posted : 14 September 2021 15:46:12(UTC)
You are in the learning curve of Smath.
It toke me ~ 6 years to convert most of my MCD 11.
Wait to glance your promised document ... Jean
Offline oscampo
#4 Posted : 14 September 2021 16:49:38(UTC)
oscampo
Colombia
Was thanked: 85 time(s) in 65 post(s)
Hallo,
Best regards,
Johannes
Please, can you share your .sm file?
Oscar
Offline Jopi
#5 Posted : 15 September 2021 10:57:37(UTC)
Jopi
Rank: Member
Here is the file.
I have inserted a random source matrix, that needs a longer calculation time than my original.
But the effect is the same.
Extract matrix element.sm (11kb) downloaded 19 time(s).
#6 Posted : 15 September 2021 15:14:57(UTC)
Here is the file.
Sorry Collab, I don't quite understand your matrix wrt Smath code.
Random [rnd(n)] LAMDA.sm (6kb) downloaded 5 time(s).
Random Scatter 3D.sm (20kb) downloaded 5 time(s).
Random_5 Matrix [RGB].sm (103kb) downloaded 4 time(s).
Online overlord
#7 Posted : 15 September 2021 15:42:20(UTC)
Turkey
Here is the file.
This product evaluation may seem small on paper.
But actually it is a huge calculation.
And it gets bigger if t.max/i.max gets higher.
It takes 26s on my pc and my CPU is i7 6700k.
Not one of the fastest but not a slow one either.
Obviously you have to wait until that product is finished.
After that you can display elements of matrix w individually, and in an instant.
SMath is smart, it won't recalculate if you try to display an element of matrix after it is finished.
It will take microseconds to show the elements of matrix.
Unless you don't change something before "the long process calculation" of course.
#8 Posted : 15 September 2021 16:10:12(UTC)
The classical Iterated Product.
Offline Jopi
#9 Posted : 15 September 2021 17:18:16(UTC)
Jopi
Rank: Member
Thank you for your answers.
My concern was NOT that the evaluation of
Matrix := complicated definition
took a long time, it was about the extraction of a single element,
Matrix[x,y]=
As i noted above, with a different definition:
Matrix := eval(complicated definition)
the following
Matrix[x,y]=
performed as expected in milliseconds.
I did not expect that a calculation, that is set to "numerical optimization", needs this additional eval() to calculate to the numerical end.
My original matrix is times bigger, but includes a lot of zeros. It now performs in a second.
Thank you , Johannes
Online overlord
#10 Posted : 15 September 2021 20:12:43(UTC)
Turkey
Because that is what eval() "may" does, usually.
Simplify expression, reduce calculation time.
I didn't get what you mentioned earlier, sorry.
I thought you were complaining about you couldn't
display elements, unless you shrink the matrix w.
on 15/09/2021(UTC)
Offline oscampo
#11 Posted : 15 September 2021 20:26:08(UTC)
oscampo
Colombia
Here is the file.
If you define your matrix as a function, you have an alternative and faster "extraction of a matrix element":
#12 Posted : 15 September 2021 21:02:30(UTC)
