SMath Studio Forum
Questions
More vector-producing vector results
This is a little similar to my last post, but different enough to warrant its own post. However, it might help to solve both. The easiest way to put this, is that I am getting 2 - 4 sized vectors for reasonably complicated equations. However, on major simplification, I have whittled one down to the following: mfos attached the following image(s):
Can you attach a screenshot of your settings under Tools> Options> calculations or the relevant settings from your settings file (as found in SettingsDirectory())? And perhaps include any of the mentioned equations? |
Hello, This was solved in the previous post ("Square Root Result" ). Turns out it was the same issue. Thanks anyhow! Edited by moderator 20 October 2013 23:53:53(UTC)
| Reason: Not specified
SMath Studio Forum
Questions
