Offline Mushoe
#1 Posted : 09 October 2013 02:11:01(UTC)
Mushoe
Please help! I am trying to do a simple natural log function and I keep getting the error " is not a valid Win32 application. (Exception from HRESULT: 0x800700C1)".
I am running v0.96 (build 4909) on Windows 7 x64.
Edited by user 09 October 2013 17:04:49(UTC)  | Reason: Not specified
Mushoe attached the following image(s):
Offline uham1867
#2 Posted : 09 October 2013 10:11:10(UTC)
uham1867
hi mushoe
if you have installed one or more WIN 32 plugin delete it, then it should work
Greetings uham67
Offline mkraska
#3 Posted : 09 October 2013 12:19:11(UTC)
mkraska
Do you use the unofficial portable distribution? If not, you might give it a try.
Edit: Link corrected
Edited by user 09 October 2013 16:40:31(UTC)  | Reason: Not specified
Online PompelmoTell
#4 Posted : 09 October 2013 12:41:53(UTC)
PompelmoTell
Hi Martin,
the link to the "unofficial portable version" does not work properly (Page not found)
on 09/10/2013(UTC)
Offline kilele
#5 Posted : 09 October 2013 14:58:48(UTC)
kilele
This is the correct link
Edited by user 09 October 2013 15:00:41(UTC)  | Reason: Not specified
Offline Mushoe
#6 Posted : 09 October 2013 17:03:10(UTC)
Mushoe
I tried removing all plugins from my install, but that did not work. I then tried the portable version and it solved my issue!
Clap
Thank you so very much!
I had defined r0 above, I just forgot to move it down when I took the screen shot. Good
Mushoe
#7 Posted : 09 October 2013 17:16:36(UTC)
Good Good
BTW I suggest you to follow the hint made by ioan92, sometimes something goes wrong with the installed version, a clean install can solve issues (tried myself this summer with an annoying red cross of death moving the vertical scrollbar)
regards,
Davide
Offline Mushoe
#8 Posted : 27 November 2013 20:19:21(UTC)
Mushoe
Just a follow up. I have been using the unofficial portable version for a while now and it has been working as expected with no strange errors. Thanks again to all for the help!
http://smath.info/wiki/(S(iymz0v3hvaquj12ic1kr4yfo))/Default.aspx?Page=SMath%20with%20Plugins
