Offline Marcela T
#1 Posted : 17 June 2021 18:16:00(UTC)
Marcela T
Rank: Member
Woman
Colombia
is it possible to import a file in txt to the smath and organize it by columns and rows???
Offline overlord
#2 Posted : 17 June 2021 19:49:55(UTC)
Turkey
If you mean a comma separated file (csv), yes it is possible with importData().
Offline Marcela T
#3 Posted : 17 June 2021 21:39:09(UTC)
Marcela T
Rank: Member
Woman
Colombia
I allow your instrruccions, i dont know if i am doing ok, the name of the file is "ppp" and it shows me in the smath studio thats it is not reconized.
Offline overlord
#4 Posted : 17 June 2021 21:49:26(UTC)
Turkey
If you could provide your file, it would be easier to check and input correct delimiters.
If you don't want to, just put a couple of lines. It can help to determine the function values.
Edited by user 17 June 2021 21:55:51(UTC)  | Reason: Not specified
Offline Marcela T
#5 Posted : 17 June 2021 22:18:48(UTC)
Marcela T
Rank: Member
Woman
Colombia
this it is the file, thanks for your help
ppp.txt (169kb) downloaded 26 time(s).
Offline overlord
#6 Posted : 17 June 2021 22:27:20(UTC)
Turkey
You should write "ppp.txt" where you indicate your file.
You also just have to delete the first line from your data file.
It creates conflict between your function and data.
Data it provides don't match pattern of function.
So in result data can't be read.
Check below.
PS: martin is also right about getting partial data down below.
Edited by user 18 June 2021 00:17:11(UTC)  | Reason: Not specified
Offline mkraska
#7 Posted : 17 June 2021 23:12:18(UTC)
mkraska
You can access differently formatted sections by reading them separately.
import.sm (5kb) downloaded 16 time(s).
