Offline guralM
#1 Posted : 10 June 2021 21:54:47(UTC)
guralM
hi, sorry in advance if this is wrong place, but is this website correct?
https://howkgtolbs.com/kg-m3-to-lb-ft3 I want convert few numbers from kg/m3 to lb/ft3 to calculate something
Offline overlord
#2 Posted : 10 June 2021 22:24:57(UTC)
Turkey
Apparently last decimals are not correct.
SMath gives 0.062427960576145*'lb/{'ft^3}
These two sites are same with smath.
https://calculate.plus/en/categories/density/convert/kg-per-m3/to/lb-per-ft3
https://www.convertunits.com/from/kg/m3/to/lb/ft3
And you can always use smath cloud computing.
https://en.smath.com/cloud/sheet
Edited by user 10 June 2021 22:27:56(UTC)  | Reason: Not specified
#3 Posted : 10 June 2021 23:55:08(UTC)
2.2046226/35.314667=0.062428 ... kg/m³ => lb/ft³
Guest (2)
