Offline experimentator
#1 Posted : 26 May 2013 14:08:29(UTC)
experimentator
Rank: Member
Spain
First of all, I think Andrey the work you do is astonishing and thanks to all the community, too.
I have a problem, waht is wrong?
experimentator attached the following image(s):
Learning by doing
Offline mikekaganski
#2 Posted : 26 May 2013 15:25:00(UTC)
mikekaganski
Was thanked: 151 time(s) in 107 post(s)
1. You should not use i's and j's as indices, because they also designate imaginary part of complex numbers. In some versions some of them, or both, cause errors when used otherwise.
2. You could use I and j as indices of k, not of C[k] or A[k].
It would be better if you attach the file.
Edit: Oh, it looks like you cannot assign anything to nested matrices...
Seems like you only can assign the whole new matrix to C[k].
Edited by user 26 May 2013 15:36:48(UTC)  | Reason: Not specified
Best regards,
Mike Kaganski
Offline omorr
#3 Posted : 26 May 2013 15:30:38(UTC)
omorr
Serbia
Try this
for(k,range(1,rows(A)),line(for(i,range(1,rows(Cool),for(j,range(1,cols(Cool),el(c,i,j):el(B,i,j)/el(el(A,k),i,j))),el(C,k):c,2,1))
C=mat(mat(4,2.5,2,1.75,1.6,1.5,3,2),mat(0.571,0.625,0.667,7,4,3,3,2),2,1)
It seems that direct assignment of a matrix element in a nested matrix is not allowed. Try to avoid such constructions - it will give trouble.
Edited by user 03 September 2014 16:35:20(UTC)  | Reason: Not specified
Offline mkraska
#4 Posted : 26 May 2013 15:30:52(UTC)
mkraska
The problem is in using nested indices on the left hand side. That does not work just as linear indexing of pre-allocated matrices does not work (would save a loop in the example).
File Attachment(s):
Matrizenindizierung.sm (7kb) downloaded 36 time(s).
#5 Posted : 26 May 2013 20:58:08(UTC)
experimentator
Rank: Member
Spain
I thank you all!
Learning by doing
