Originally Posted by: mkraska Andrey, for testing of viewer application it would be very helpful, to have some shortcut for export. This could be a button in the tool bar or a hot key. It could export the sheet to the recently selected format and name (the latter reset upon each change of the sheet name. Ctr-S still would save the sheet as .sm file. If I understood you well, then yes, I will add an option to make it possible to export worksheet with all current changes as an *.sm file. It will be only an option in the File > Properties dialog (2-nd ta with "false" by default. This is because one of the main ideas of SMath Viewer - ability to protect your source worksheet. Originally Posted by: mkraska currently, the file property settings for author and company are not reflected in the generated exe file. The file manager displays the metadata of the plugin, not of the exported sheet. I guess that changes are limited to the commercial version (which is perfectly ok) Hmm. Author should be specified in file properties. Try to hover output exe with a mouse: Originally Posted by: mkraska I also guess, that the other metadata will some day go to an "About" button of the exported app, won't they? Exactly! Originally Posted by: mkraska It would be nice if the exported app would include only the required plugins. Currently, everything is exported, even those which are disabled in the plugins manager. Advanced users typically have their installation full of stuff, which then blows up even the simplest example apps. An alternative is, of course, to have different installations with different selections of installed plugins. That, however, is hard to maintain consistently. I see, of course, the problem of how to determine the dependencies in multifile plugins just like the maplewrapper or dataexchange. If there is an easy solution, that would be welcome. You're right. I didn't know any common way to determine the dependencies between DLLs in plugin's directory (especially for unmanaged DLLs). But I think I've found a solution already, so in the next versions this will not be a problem anymore. Originally Posted by: mkraska EDIT: The print preview looks like it would show the title or filename but fails to do so. Correct. Will fix it. Originally Posted by: mkraska EDIT: For commercial users might be important to check the print preview, because it contains more information than the app GUI (e.g. covering of variable names and implemented formulas by description strings is lost) Yeah, will think about it. Thank you. Originally Posted by: mkraska EDIT: Does the statement "SMath viewer is free for learning" include teaching in acedemic context? Yes, absolutely. Originally Posted by: mkraska EDIT: How can I change the language setting of the viewer application (e.g. in order to test translated versions)? For now you need to change OS localization setting to test translations. Plan to add additional toolbar button with all available languages listed. Thank you, mkraska! Best regards, Andrey Ivashov.
