The Smath native FindRoot does not re-seed itself, thus does not re-seeds
within a classical forloop. However, it can be called algo style from external
command line ... more: it will solve auto-range on the length of the
input vectors 'xx, yy'
sol(j,xx,yy) ... int his case solving for 'xx, yy' of length 'j'.
As you open this document, the system is in its very initial state.
1. calculate
2. plug back in the initial vector ... calculate
3. keep going until both sanity vectors reach 0.000000000000
4. No more bananas for the monkey FindRoot
The convergence [number of iterations] can't be predicted as it depends
upon the FindRoot robustness wrt the equalities system.
This type of external looping was designed for a Mathcad 11 application
Same but different is solve(,,,) applied to Pipe Data Smath.
different because in this case solve(,,,,)
can be declared above use ... declared as wild algo.
FindRoot does not support decalation.I may not have completely cracked, but it works.
Enjoy, comments welcomed.
Project Solve Flashing Copy.sm (204kb) downloaded 50 time(s).
