SMath Studio Forum
Bugs & Problems
Edit fails to trigger automatic re-calculation
consider the following example: j:2for(j,range(1,4),a:j)j=4Now edit the loop expression and change it to any expression without assignment operator with or without j in it for(j,range(1,4),a)When leaving the math region, nothing happens. j=4As soon as you trigger re-calculation manually, j changes to 2, indicating that the loop iteration is not performed in the global namespace. j=2Still there is iteration as you can see using trace(j) as loop body. for(j,range(1,4),trace(j))I think, that changes in expressions should trigger re-calculation if that option is set in the options. Also, I really discourage the use of implicit variable scoping magics. I guess that it is not by intent to overwrite the global imaginary unit i depending on what precisely you do inside iterations with i as counter. If the mentioned dependency is a feature and not a bug I would like to learn how this contributes to comprehensable documents. Best regards, Martin Kraska Edited by user 23 March 2014 18:35:46(UTC)
Joined: 14/12/2012(UTC) Posts: 23 Location: Neverland
Was thanked: 15 time(s) in 9 post(s)
Without reading this post, I just posted the same thing in the clear discussion.
SMath Studio Forum
Bugs & Problems
