Joined: 14/10/2012(UTC) Posts: 2 Location: Western Cape
Hello, first of all, thank you for a really good program.
My question: Is it possible to display a symbolic expression a a different form. For example, I have a transfer function in factored form, but I would like it expanded so that I can easily find the various coefficients of s, s^2, ... etc.
Is there a way to do this? (probably a noob question?)
Using 0.95
Joined: 25/04/2013(UTC) Posts: 8 Was thanked: 1 time(s) in 1 post(s)
sorry to bump an ancient topic but this would be reaaaaallllyyy handy.
For example (-1+λ)*(1+λ)+5 --> = (-1+λ)*(1+λ)+5. I can't find any way to make it perform the multiplication and end up with λ^2 + 4.
Any Ideas?
1 user thanked natezimmer for this useful post.
Joined: 15/04/2012(UTC) Posts: 1,987 Was thanked: 1124 time(s) in 721 post(s)
Originally Posted by: natezimmer For example (-1+λ)*(1+λ)+5 --> = (-1+λ)*(1+λ)+5. I can't find any way to make it perform the multiplication and end up with λ^2 + 4.
You can use SMath Studio with Maxima (see signature for download link) File Attachment(s): simp.sm (5kb) downloaded 132 time(s). mkraska attached the following image(s): |
Originally Posted by: mkraska Originally Posted by: natezimmer For example (-1+λ)*(1+λ)+5 --> = (-1+λ)*(1+λ)+5. I can't find any way to make it perform the multiplication and end up with λ^2 + 4.
You can use SMath Studio with Maxima (see signature for download link) Did I ever mention how handsome you are? That portable plugin w/ max version is aawweeessomme! I would thank you a million times but I get an error when I try to do it even once.
Edit:
Still having issues. I can't prevent max from factoring. if I change the example to (-2+λ)*(1+λ)+5 --> 3+λ*(-1+λ)
I've tried expand, multthru ...ect without luck. Attempting to get λ^2 -3*λ +λ
Sometime Maxima-results are modified by SMath's simplifier. If you set optimization->None then you get the original Maxima answer.
Maxima(expandwrt((-2+λ)*(1+λ)+5,λ))=λ^2-λ+3 |
