SMath Studio Forum
Bugs & Problems
Case Sensitivity in Insert Function Dialog
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1127 time(s) in 723 post(s)
Hi, The Insert-Function Dialog does not list the built-in functions min and max if the customFunctions plugin is active. In that case only Min and Max are listed. However, both versions are available via dynamic assistant. Perhaps the dialog lacks case sensitivity at some point? Best regards, Martin Kraska mkraska attached the following image(s): |
SMath Studio Forum
Bugs & Problems
