SMath Studio Forum
Bugs & Problems
[SS-3567] File corrupted after using region protection option
Hello, I used protection regions on my smath sheet. Everything went fine until I close the sheet and try to reopen it. I can't expand areas no more (no "+" or "-" available anymore at the begining of the area), nor can I run calculations... The file seems corrupted. It weights only 20kB... Someone help please! File is available here : corrupted file.sm (21kb) downloaded 11 time(s).. Thanks a lot
Confirmed and reproduced; (also, reproducible using copy and paste on opened worksheets). Unfortunately everything in the protected area is lost (not saved, hence not recoverable). Bug reported as SS-3567. Edited by user 03 October 2018 20:33:34(UTC)
Thank you for having a look at it anyway.
Originally Posted by: cecile Thank you for having a look at it anyway. Thank you for reporting; as posted in the BTS the issue is fixed now and will be part of the next release. Edited by user 28 October 2018 12:31:18(UTC)
| Reason: fixed in SMath Studio 0.99.6858 |
Joined: 20/11/2016(UTC) Posts: 7 Location: Bogota Was thanked: 1 time(s) in 1 post(s)
Hi, I find a similar error when I use region protection and secondary areas are contained in the area. When opening the sheet all content is protected I hope it could be improved in future versions.
SMath Studio Forum
Bugs & Problems
