Offline mareschn
#1 Posted : 22 May 2012 17:05:28(UTC)
mareschn
When trying to open mathcad files, it displays a message indicating an "Input string not in a correct format"
Edited by user 31 July 2012 18:01:05(UTC)  | Reason: Not specified
Offline omorr
#2 Posted : 22 May 2012 17:16:45(UTC)
omorr
Serbia
I suggest you not to try to open Mathcad files. SMath is not a Mathcad clone and I do not believe it would ever be. SMath can only open rather simple Mathcad *.xmcd files and there is no Mathcad<->SMath converter or anything similar.
Offline mareschn
#3 Posted : 22 May 2012 17:27:33(UTC)
mareschn
I'm sorry -I was not concise enough -I cannot open the *.xmcd files I created with Smath 0.93 (saved in this format so a colleague can open with his mathcad)
Offline omorr
#4 Posted : 22 May 2012 17:31:55(UTC)
omorr
Serbia
Why do not tell your college simply to download SMath and send him your *.sm file. It is much simpler Good
Offline mareschn
#5 Posted : 22 May 2012 17:40:50(UTC)
mareschn
This might be what it takes to convince him Biggrin Seriously though, he was very impressed with it a few weeks ago when I showed it to him. He even presented it to his classroom of students, some of which were overjoyed to see it. Thank you for all that you do.
Offline omorr
#6 Posted : 22 May 2012 17:45:50(UTC)
omorr
Serbia
You are welcome Good
Enjoy using SMath.
Offline resplin
#7 Posted : 08 June 2012 00:22:57(UTC)
resplin
I found that if I opened the mathcad file with wordpad and deleted everything from <textStyles> to </textStyles> SMath would open the file.
Offline Andrey Ivashov
#8 Posted : 10 June 2012 22:03:52(UTC)
Fixed.
Offline resplin
#9 Posted : 11 June 2012 20:08:23(UTC)
resplin
Thank you for working on this issue. It still does not seem to work for the mathcad sheets that I am using. I still have to delete everything between the <textStyles>. Please let me know if you need anything else from me. I would be happy to send you a copy of one of the mathcad sheets that are causing the issue.
#10 Posted : 11 June 2012 20:31:01(UTC)
Yep, it seems I need an example sheet to reproduce the issue.
Best regards, Andrey Ivashov.
Offline mareschn
#11 Posted : 19 June 2012 23:40:45(UTC)
mareschn
Ver. 0.95 still has the issue with *.xmcd files created with ver. 0.93... Still shows "Input string was not in a correct format"
File Attachment(s):
xmcd.xmcd (7kb) downloaded 44 time(s).
Offline stefano
#12 Posted : 02 July 2012 21:25:31(UTC)
stefano
I confirm, after updating the 25-June-2012 (SMath-Studio-0-95-4559), the problem is not solved yet. The new versions of Smathstudio not open xmcd files that older versions opened. thanks ST
Offline jruby411
#13 Posted : 16 July 2012 22:21:50(UTC)
jruby411
Andrey has been working hard to squash the bugs I introduced when trying to improve this plugin.
I have fixed the issue and committed the file.
I will try to attach the new dll if you need it right away.
Jeff.
File Attachment(s):
XMCDFileType.zip (17kb) downloaded 105 time(s).
Offline Justin Ralston
#14 Posted : 19 July 2012 00:56:40(UTC)
Justin Ralston
New Zealand
Great work Guys Clap
I have tried the new .dll with some old basic files and it works ok
I have tried this retaining wall design sheet and it does not work so well.
Tried a cut and paste from mathcad but that just gives a picture of the text in smath.
Any suggestion on how to get a better import?
Justin
File Attachment(s):
Timber RW 5 kPa Surchargexxxx.xmcd (2,945kb) downloaded 43 time(s).
Offline mareschn
#15 Posted : 31 July 2012 18:00:11(UTC)
mareschn
New version 0.95 (4594) works great! Thanks!
