2 Pages12>
Offline ElSid
#1 Posted : 19 March 2018 22:21:45(UTC)
ElSid
Brain fried. Looking for some help re-structuring this. At least the students understood this math Good Tank Wall Temperature Insulation.smz (952kb) downloaded 32 time(s).
Offline Ernesto
#2 Posted : 20 March 2018 01:58:25(UTC)
Ernesto
Nicaragua
Was thanked: 13 time(s) in 11 post(s)
What exactly do you want to do?
#3 Posted : 20 March 2018 03:41:47(UTC)
https://www.sfu.ca/~mbahrami/ENSC%20388/Notes/Staedy%20Conduction%20Heat%20Transfer.pdf
Offline ElSid
#4 Posted : 20 March 2018 17:04:27(UTC)
ElSid
Sorry. I'm looking to have SMath do the algebraic manipulation ...
#5 Posted : 20 March 2018 21:20:08(UTC)
Sorry.I'm looking to have SMath do the algebraic manipulation ...
Smath will not do it by itself, unless appropriately coded.
http://se.asee.org/proceedings/ASEE2004/P2004127chemiHOD.pdf
Offline ElSid
#6 Posted : 20 March 2018 23:31:24(UTC)
ElSid
Different approach. Trying to use FindRoot. Tank Wall Temperature Insulation(C).smz (243kb) downloaded 27 time(s).
Right now, I have a manual override.
Edited by user 21 March 2018 00:11:04(UTC)  | Reason: Not specified
#7 Posted : 21 March 2018 07:04:01(UTC)
Different approach
Attach *.sm ... instead.
Offline ElSid
#8 Posted : 21 March 2018 14:57:29(UTC)
ElSid
Jean,
This is Rev "C" so it's a NEW file
With that said, I am attaching Rev "D". I cannot figure out the error. Value is now coming in correctly. Attached is a screen shot of a "scratch" file I created with just the variables Tank Wall Temperature Insulation(D).sm (201kb) downloaded 14 time(s).
Edited by user 21 March 2018 16:00:06(UTC)  | Reason: NEW File and screenshot
Offline ElSid
#9 Posted : 21 March 2018 21:07:44(UTC)
ElSid
Not sure what I did, but FindRoot seems to have worked ...
Sanity check Rev E? Tank Wall Temperature Insulation(E).smz (103kb) downloaded 12 time(s).
Next is to add a plot --> Ins. thickness vs. T1
#10 Posted : 21 March 2018 23:29:30(UTC)
There is a closely related example in Mathcad, just a bit [a big bit] more involved.
My expertise on that is about a thermostated tank, once insulated from some of the
reference you mentioned, and local standards vary.
*.smz = 103 kB ... *.sm = 102 kB
Offline ElSid
#11 Posted : 22 March 2018 18:40:43(UTC)
ElSid
Graphing problem with units not cancelling out. Go to bottom of page. Essentially, all values are calculated with Kelvin. I change the units in the array to F and we are OK.
I then try and divide by F, and I get K over F. So I cannot plot ...
Also, my program updated this morning to 0.99.6654
File version F Tank Wall Temperature Insulation(F).smz (106kb) downloaded 16 time(s).
Offline mkraska
#12 Posted : 22 March 2018 19:41:14(UTC)
mkraska
2018-03-22 17_40_02-SMath Studio - [Tank%20Wall%20Temperature%20Insulation(F).smz_].png
#13 Posted : 22 March 2018 19:52:44(UTC)
In red below WS
Tank Wall Temperature Insulation(F).smz (107kb) downloaded 13 time(s).
Offline ElSid
#14 Posted : 22 March 2018 20:18:55(UTC)
ElSid
Jean,
I need the Y axis in degree F. This plots to Kelvin.
Also, why did you define "isolate"? I should be able to use augment straight up ... shouldn't I?
Also, how did you scale the graph?
Edited by user 22 March 2018 20:36:57(UTC)  | Reason: Added question
#15 Posted : 22 March 2018 20:47:18(UTC)
Jean,
I need the Y axis in degree F.This plots to Kelvin.
Also, why did you define "isolate"?I should be able to use augment straight up ... shouldn't I?
I'm reworking a bit the project, pretty messy.
Hope it's correct from your reference(sss)
Bloody Imperial system !
Instead of scaling the graph, use X_Y Maxima.
Isolate to get rid of Units for plotting.
Maybe multiply by the conversion K => F
Offline ElSid
#16 Posted : 22 March 2018 20:51:32(UTC)
ElSid
Thank you Jean. The units should be adjustable per https://en.smath.info/fo...nits-does-not-work.aspx. I was trying to use the built in units to convert, but had the same issues going to degrees C.
Edited by user 22 March 2018 21:02:41(UTC)  | Reason: Not specified
#17 Posted : 22 March 2018 21:20:02(UTC)
Nice worksheet.
Have you tried with the solution porposed by martin? (°F instead of °C of course)
2018-03-22 19_16_47-SMath Studio - [Tank%20Wall%20Temperature%20Insulation(F).smz_].png
2018-03-22 19_23_29-SMath Studio - [Tank%20Wall%20Temperature%20Insulation(F).sm_].png
Edited by user 22 March 2018 21:24:07(UTC)  | Reason: Not specified
Offline ElSid
#18 Posted : 22 March 2018 22:28:44(UTC)
ElSid
Martin,
I totally spaced your graphic. Can you explain the -0 degree C or F concept as this was not intuitive? I understand the delta T since we are subtracting temperatures ... Maybe this is just the work around and I answered myself
Now the better part ... a loop. As the surface temperature is allowed to remain warmer, the thickness will increase. This should be similar to the Colebrook loop. I need to find my notes on that sheet.
Edited by user 22 March 2018 23:13:05(UTC)  | Reason: Grammar
Offline mkraska
#19 Posted : 22 March 2018 23:13:17(UTC)
mkraska
Temperature gauges/units are special in that they may differ by a factor and an offset from a reference gauge. When using gauges without offset, just like K or °Rankine you can obtain the unitless numeric value by dividing the quantity by the unit. When you have an offset, you have to remove this first, hence the -0°F term. Then you divide by the relative unit matching your gauge.
on 22/03/2018(UTC)
Offline ElSid
#20 Posted : 23 March 2018 18:29:48(UTC)
ElSid
OK, going back to sanity check some values. I'll work on the look after I get the units right.
Martin,
I thought I canceled out units per your comment above in the new FindRoot equation
Version G Tank Wall Temperature Insulation(G).smz (107kb) downloaded 13 time(s). :'(
Similar Topics
Thermal Insulation (Samples)
by Jean Giraud 23/03/2018 04:00:28(UTC)
Symbolic Critical Insulation Thickness (Questions)
by ElSid 08/03/2016 18:36:34(UTC)
2 Pages12>
