SMath Studio Forum
Bugs & Problems
unit problem in matrices using max() function
If you want to get the highest value of a given Matrix you have to take care of the units. 1. all (tested) units should be the same -> if not SMath should complain about unit mismatch 2. if the first value of a matrix is zero, the result does not contain any unit. -> SMath should go to the first not zero element get its unit Edited by user 04 June 2012 10:15:01(UTC)
| Reason: Solved at least in build 9435
SMath Studio Forum
Bugs & Problems
