SMath Studio Forum
Bugs & Problems
Function parameters bug - continued?
Hello Andrey, I am not sure but I suppose this is connected with the changing in function arguments bug discussed in Functions behave differently in 0.9Here is an example using integration. 1. This is the calculation at the beginning 2. This is when recalculate (F9) Here is the sm file recalculate problemIt reported that variable "x" is not defined (actually, it should be that way). Do not understand what happened here? Regards, Radovan Edited by user 26 January 2012 03:08:54(UTC)
The previous post had a problem with date (Internal Forum problem). It was not reported in the recent post lists. |
SMath Studio Forum
Bugs & Problems
