Offline Greg Locock
#1 Posted : 30 August 2009 08:52:43(UTC)
Greg Locock
Using the factorial for loop example
I ran the for loop example, eg with the counter set to 173
a:=1
for i:1,i<173,i:=i+1
a:=a*i
a=
which gives a remarkably small answer without an error message
This software has great potential by the way, thank you.
Offline omorr
#2 Posted : 30 August 2009 17:39:14(UTC)
omorr
Serbia
I think you are right. I also suppose it is a bug!
Open in SMath Cloud
Try yourself, please
173!=#
or
173!—#
The error has been issued this time - overflow!.
Edited by user 30 August 2009 17:44:45(UTC)  | Reason: Not specified
Offline Greg Locock
#3 Posted : 30 August 2009 18:02:56(UTC)
Greg Locock
Oh, sure I have no problem with the factorial function overflowing, what I didn't like was the absence of an error message in the little program. You have incidentally answered another puzzle, how to use the "for" keybutton. Cheers greg
Offline omorr
#4 Posted : 30 August 2009 18:16:21(UTC)
omorr
Serbia
A agree with you. Andrey will answer on this, for sure. Btw., I think he is rather busy at the moment. In a day or two a new release should be here.
You are welcome. Some things could be a problem at the beginning because there is no Help or Tutorial yet.
Btw., I hope you understood these two ways of "for" loop? The second one is obtained with "range" function. If not, let me know and I will give you a detailed explanation.
Offline Andrey Ivashov
#5 Posted : 30 August 2009 19:04:16(UTC)
Fixed. Thank you.
Offline omorr
#6 Posted : 30 August 2009 19:46:27(UTC)
omorr
Serbia
Thank you Good
#7 Posted : 31 August 2009 01:19:10(UTC)
Finally, in order to avoid possible errors in the calculations below I've decided to forbid using variable, that caused an error.
Release will be available tomorrow in the midnight (01.09.2009).
Edited by user 31 August 2009 01:21:15(UTC)  | Reason: Not specified
Guest (2)
