SMath Studio Forum
Questions
error calculating sin function
Joined: 13/05/2011(UTC) Posts: 17 Location: coolum bch, Australia
Looking down through a sheet I had just completed I found a curious result for a simple sin calculation, but can't fix it....
I did see someone else in here with a similar problem, another forum member suggested changing optimisation to numeric, I did this, but with no change to the result.
Can someone else check, to ensure I'm not crazy...?
If d=35, then 1-sin(d)= 0.4264, not 1.4282 as Smath reports........
cheers,
Stu.
Hello Stu, By default, it is assumed that a dimensionless variable representing angle is in radians - not degrees. Open in SMath CloudRegards, Radovan |
SMath Studio Forum
Questions
