I'm using SMATH for a controls class that I am taking. I am getting bad values for rank of a matrix.
A=[0,1;1,0] should return a rank of 2 I keep getting a 1
Seems that you defined A as a column vector. Depending on your settings, the comma serves as decimal point or as function argument separator. type A:mat Enter This gives you a 2x2 Matrix of placeholders. mkraska attached the following image(s): |
The comma's are from my Scilab equation, sorry about the confusion. It looks like my problem is in the way I calculate the matrix. Attached is a quick test I put together. Ward.Holloway attached the following image(s):
You have made an error defining Γ You need to use the augment() function; without this function you create a nested matrix. BTW there is a bug because calling directly the rank function when the first matrix element is a nested matrix, a type conversion error appears. regards, w3b5urf3r Edited by user 21 February 2013 19:12:44(UTC)
| Reason: Not specified File Attachment(s): rank.sm (12kb) downloaded 13 time(s). Davide Carpi attached the following image(s): |
Excellent, thanks to both of you.
