Offline TopUser2000
#1 Posted : 27 March 2024 04:36:24(UTC)
TopUser2000
Rank: Member
Belarus
Hello. Tell me, please, is it possible to see the set numerical values when calculating formulas in the program? I mean, instead
of
a = 5, b = 6,
a + b = 11
see a = 5, b = 6,
a + b = 5 + 6 = 11
Offline churichuro
#2 Posted : 27 March 2024 15:21:28(UTC)
churichuro
Mexico
Was thanked: 27 time(s) in 22 post(s)
test1.sm (6kb) downloaded 1 time(s).
Edited by user 27 March 2024 15:29:51(UTC)  | Reason: Not specified
Offline TopUser2000
#3 Posted : 27 March 2024 22:56:37(UTC)
TopUser2000
Rank: Member
Belarus
In the simplest case, this option would be suitable, but if the formula is a little more complicated, then we get a pile of fractions and numbers
Offline alyles
#4 Posted : 29 March 2024 01:54:32(UTC)
alyles
FYI there has been some discussion about this feature in the past.
https://en.smath.com/for...tution-Optimization.aspx
Also a function proposed here: https://en.smath.com/for...variables.aspx#post78024
Edited by user 29 March 2024 01:56:58(UTC)  | Reason: Not specified
Offline TopUser2000
#5 Posted : 29 March 2024 05:26:08(UTC)
TopUser2000
Rank: Member
Belarus
Originally Posted by: alyles Go to Quoted Post
FYI there has been some discussion about this featurein the past.
But there is no solution for this request there...
Offline overlord
#6 Posted : 29 March 2024 08:29:38(UTC)
Turkey
There is also this topic.
https://en.smath.com/forum/yaf_postst21565_Show-values.aspx
What you seek is won't be simple, as you requested and applicable however.
This situation is explained in detail by mkraska at the link above.
Offline Kenny Lemens
#7 Posted : 29 March 2024 17:58:56(UTC)
Kenny Lemens
Was thanked: 61 time(s) in 38 post(s)
Greetings,
Alvaro has built a function to address this feature request:
Note: it has a little bit of a learning curve, but is worth considering never-the-less.
May this be of Good Help;
⚜ Kenny Lemens, P.E. ᵂᴵ
Offline TopUser2000
#8 Posted : 30 March 2024 07:40:58(UTC)
TopUser2000
Rank: Member
Belarus
I don't see the result in the attached screenshots of how it works. A jumble of formulas where there is no clear answer.
