Joined: 01/12/2023(UTC) Posts: 1 Location: Nieuw-Lekkerland
Hello dear Smath Users, I accidentally pressed the keyboard once and created an Else-If statement like this: Lately I have been struggling to find this option of an Else If statement on Smath studio. There seemed to be no information on this topic anywhere. So I figured it out myself: --Type "if" and press the TAB key. --Click in the place above the "Else" portion of the If statement. --Now press ";" and you should get an If Else-If statement. Kind Regards!
1. if/else from program palette 2. alternately from fx menu 3. if/otherwise from fx menu cases
You add and remove entries just as within vectors or lists (sys) or command blocks (line). If you don't need command blocks in the entries, then probably the cases() function from the custom functions plugin is more reader-friendly than cascades of if(). |
Mathcad has if/else in two styles like Smath and single line => very convenient compactor.
Joined: 23/07/2013(UTC) Posts: 1,129 Was thanked: 510 time(s) in 340 post(s)
Originally Posted by: Captain_North Lately I have been struggling to find this option of an Else If statement on Smath studio. Original if() didn't have else if just over a year ago. Only persistent else statement existed with one if. Nowadays you can even eliminate else. Regards
