Joined: 27/01/2023(UTC) Posts: 30 Was thanked: 3 time(s) in 3 post(s)
For a simple harmonic oscillator with mass "m" (kg) and spring constant "k" (N/m), the angular frequency of oscillation is sqrt(k/m). If we used the SI units, the angular frequency unit should be (rad/s) but when I use units in SMath it gives the answer in Hz.. So, is there a way that I can correct the units for an answer? Thanks in advance Edited by user 25 November 2023 17:15:45(UTC)
| Reason: Not specified
Joined: 10/12/2009(UTC) Posts: 249 Location: Cali, Colombia Was thanked: 87 time(s) in 66 post(s)
You can change units in this way... Oscar
1 user thanked oscampo for this useful post.
1 user thanked Oichi for this useful post.
