Offline ioan92
#1 Posted : 27 October 2023 02:52:03(UTC)
ioan92
France, Metropolitan
Was thanked: 153 time(s) in 119 post(s)
Hello Everybody,
Please, do you have some smarter solutions to write a long formula like this?
I put inside the file my actual primarily Sad range of know-how.
How to compact.sm (14kb) downloaded 7 time(s).
Do you expect some improved solutions embedded in the system?
For instance: one alone split of a line seems in my opinion as being not enough.
Thanks for your attention,
Ioan
Edited by user 27 October 2023 04:11:16(UTC)  | Reason: Not specified
Offline NotRetiredYet
#2 Posted : 27 October 2023 05:37:21(UTC)
NotRetiredYet
Was thanked: 2 time(s) in 1 post(s)
I don't have SMath here at work (company policy), but the following technique should work. It works in Mathcad, which I do have at work.
Set the function equal to the sum of a four-element column vector, then split the function definition at the three plus signs that separate the major elements of the definition and drop these pieces into the column vector. Please pardon any typos on my part.
thanks 2 users thanked NotRetiredYet for this useful post.
on 27/10/2023(UTC),  on 27/10/2023(UTC)
#3 Posted : 27 October 2023 06:22:03(UTC)
Originally Posted by: ioan92 Go to Quoted Post
Please, do you have some smarter solutions to write a long formula like this ?
The undocumented maple(op) has hidden virtue of simplifying.
Works fine your long formula ... 4th option.
Jean.
Maths How to compact maple(op).sm (23kb) downloaded 18 time(s).
Offline ioan92
#4 Posted : 27 October 2023 06:34:35(UTC)
ioan92
Hi NotRetiredYet, Greetings from an AllreadyRetired,
Thank your for your suggestion. It's simplier and it works good:
Best Regards,
Ioan
Offline ioan92
#5 Posted : 27 October 2023 06:54:35(UTC)
ioan92
Jean.
Bonjour Jean,
Thank you for your proposal. Of course it could be seen as a forth solution.
As I see, Maple turns a little bit the terms but finally we heve always a sum of four main terms.
Merci encore,
Ioan
#6 Posted : 28 October 2023 09:04:46(UTC)
Merci encore ... Ioan
A great application of maple(op)
Suppose you have a long Lagrange canonical polynomial,
generously furbished of 15 D coefficients.
Tedious to collect all the coefficients by hand.
Click/click/done maple(op(Poly(x)))
Don't expand symbolic expr(x):=maple(op(Poly(x)))
... below expansion, set x:=1
evaluate the expansion ... all coefficients collected in vector.
Take care Ioan ... Jean.
Offline Noah Brown
#7 Posted : 01 November 2023 15:00:55(UTC)
Noah Brown
Works fine your long formula ... 4th option.immaculate grid
Jean.
thankssssss Clap Clap
