Offline ioan92
#1 Posted : 24 September 2023 19:45:23(UTC)
ioan92
France, Metropolitan
Was thanked: 153 time(s) in 119 post(s)
Hello Everybody,
I have a small practical question:
How to split a long line (formula) on two or more lines.
I think that the subject was explained somewhere but I’m not sure about.
I know the primary solution of allocation variable names for the parts of the formula, but…
Thanks for your help.
Ioan
#2 Posted : 24 September 2023 20:20:16(UTC)
If your formula is piecewise composed of ± pieces, stack those pieces.
#3 Posted : 25 September 2023 01:13:40(UTC)
Composite of [+,-,/] may be reduced built-in Smath numden
on 25/09/2023(UTC)
Offline mkraska
#4 Posted : 25 September 2023 02:48:46(UTC)
mkraska
Write an expression, put the cursor to where you want a line break and press Ctrl-Enter.
This works only once in a formula, not inside results and not inside brackets.
on 25/09/2023(UTC),  on 25/09/2023(UTC)
Offline Kenny Lemens
#5 Posted : 27 September 2023 17:16:56(UTC)
Kenny Lemens
Was thanked: 62 time(s) in 39 post(s)
Greetings,
You could also word-wrap your formula:
__________________________ *
where the 'string' uses newline characters to force on the next line (\000A\ is the special code SMath uses, just copy/paste this and it will word-wrap the string). You can copy and paste the following into your worksheet:
Code:
"a+b+\000A\0+c+d+\000A\0+e+f"
  • write your math expression as a 'string'
  • pass that value through the str2num() function; it will be evaluated
*There is an issue:
May this be of Good Help;
⚜ Kenny Lemens, P.E. ᵂᴵ
thanks 1 user thanked Kenny Lemens for this useful post.
on 27/09/2023(UTC)
#6 Posted : 27 September 2023 19:22:56(UTC)
I have yet to see such long formula from native Engineering.
If your formula results from symbolic expansion... try maple.
For curiosity and help, show an image of that formula.
I have a 25 pages long formula ... Nothing can be done !
on 27/09/2023(UTC)
Offline ioan92
#7 Posted : 27 September 2023 20:30:18(UTC)
ioan92
Thank you all for your kind answers.:'(
In fact, I looked more to something like in Mathcad:
(without limitations as mentioned by Martin - only one shot)
https://www.mathcad.com/...moves%20down%20a%20line.
Best Regards,
Ioan
Edited by user 27 September 2023 20:36:03(UTC)  | Reason: Not specified
#8 Posted : 27 September 2023 20:33:47(UTC)
Kenny Lemens
Greetings,
I have used Mathcad's split feature as well and I can understand your plight. Keep in mind some other alternatives to present your data. For instance, you can use the a cases() function to organize your criteria/responses in a compact manner:
Code:
cases(#,#,#,#,#,#,#,#,#,#,#,#,#)
You can also explore sum() function with a matrix in it:
Code:
sum(mat(#,#,#,#,#,#,#,#,#,9,1))
or just the system of equations feature:
Code:
sys(#,#,#,#,#,#,#,#,8,1)
Finally, you can just select your math statement and decrease the font size such that your equation will fit on the page. I have resorted to decreasing the font down to font size [2] in order for my matrix/tabulated data to fit on one page width; it served my purposes. [2023-09-28]
Also: Jean, Thank you for the good laugh! I always enjoy your litany of responses.
Edited by user 28 September 2023 23:51:35(UTC)  | Reason: Followup to the Acutal Topic at Hand; Followup to Jean Conversation in brown; additional 'trick' in
on 27/09/2023(UTC)
#9 Posted : 28 September 2023 00:38:19(UTC)
Originally Posted by: Kenny Lemens Go to Quoted Post
- even better! you can post an image of YOUR 25 pages long formula; You are correct that I am curious of this formula.
I won't show that f(x,y) symbolic expansion.
Always nice to read you Kenny ... Jean.
Offline overlord
#10 Posted : 28 September 2023 02:10:54(UTC)
Turkey
Was thanked: 510 time(s) in 340 post(s)
Ioan, can I ask why did you delete all your posts?
Offline ioan92
#11 Posted : 28 September 2023 08:52:22(UTC)
ioan92
Hi Overlord,
Of course you can ask...
Have a nice day,
Ioan
Offline Basoier
#12 Posted : 20 December 2023 16:27:41(UTC)
Basoier
Hi Overlord,
Have a nice day,
Ioan
I think you understand
Guest (2)
