SMath Studio Forum
Bugs & Problems
Problems with release of MaximaPlugin
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1127 time(s) in 723 post(s)
We tried to release an update of the Maxima plugin in the release manager. There was no obvious hint on something going wrong. Yet, when trying to access the new version from within SMath Studio, the installation fails. The build log from the release manager shows some errors:
14-07-2023 11:55:05. - MaximaPlugin.dll obfuscated. 14-07-2023 11:55:05. 14-07-2023 11:55:05. Signing assemblies... Error information: "Error: Store IsDiskFile() failed." (-2147024893/0x80070003) SignTool Error: An unexpected internal error has occurred. Error information: "Error: Store IsDiskFile() failed." (-2147024893/0x80070003) SignTool Error: An unexpected internal error has occurred. 14-07-2023 11:55:05. - MaximaPlugin.dll dual-signed. 14-07-2023 11:55:05. 14-07-2023 11:55:05. Creating result archive... 14-07-2023 11:55:05. - Done. 14-07-2023 11:55:05. ------------------------------ 14-07-2023 11:55:05. Files produced: 14-07-2023 11:55:05. - [^MaximaPlugin.zip] (2,07 M 14-07-2023 11:55:05. Task completed.
We observed that the directory name of the plugin has changed. Initially it was SMath\extensions\plugins\44011c1e-5d0d-4533-8e68-e32b5badce41\1.98.8203.36407 When installing into an new sandbox (portable version) I get this: \SMath 8348\extensions\plugins\f6052893-60c5-4ba7-a0b1-3f7ed33492d9\0.3.1.1595 So for now it seems that we spoiled the maxima plugin in the online gallery. Is there any way to roll back the changes and find out what was the problem? |
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,652 Location: Italy Was thanked: 1339 time(s) in 878 post(s)
You can delete anything published using the files manager (link in the homepage footer) I suggest to search f6052893-60c5-4ba7-a0b1-3f7ed33492d9 in the sources (might be the guid of a dependancy?); solution and project files seems fine at first glance. Edited by user 14 July 2023 14:37:09(UTC)
Originally Posted by: Davide Carpi (might be the guid of a dependancy?) if you open the config file in the %appdata% folder, you get this: Code:0.3.1.1595
0
SharpVectors.Rendering.Gdi.dll
Joined: 10/04/2023(UTC) Posts: 22 Was thanked: 15 time(s) in 7 post(s)
The "SharpVectors.Rendering.Gdi.dll" is a file in the /lib folder of the project. I am not sure how the config data manage to have that data in it instead of the MaximaPlugin.dll.
IDK, I don't see anything obvious from the changes in the project file. You have to ask Andrey, he can check the build process and find the cause. |
Originally Posted by: Davide Carpi You can delete anything published using the files manager (link in the homepage footer) I suggest to search f6052893-60c5-4ba7-a0b1-3f7ed33492d9 in the sources (might be the guid of a dependancy?); solution and project files seems fine at first glance. Thanks, I deleted the new versions, installation should work now (tested with a portable version of build 8348). |
SMath Studio Forum
Bugs & Problems
