Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1331 time(s) in 876 post(s)
Hi someone can confirm this issue? seem that: - it's not related with optimization - appears only when you redefine an internal variable inside a line() in a user-function, making them dimensionless best regards, w3b5urf3r Edited by user 09 July 2012 12:07:52(UTC)
| Reason: Not specified File Attachment(s): Davide Carpi attached the following image(s): |
Hello w3b5urf3r,
This is related to changing the function arguments. As your function is defined as f1(x) and you actually change x then if you call your function with f1(A) then A will change as well. Your function f4(x) actually changed its argument too.
Regards, Radovan
Regards, Radovan
Hi Omorr you're right, f4(x) cause the same issue... I don't know if it's a bug or a feature, but it's quite strange for me... In my mind I think that the input variable should not be modified, unless the change it's invoked directly (A:=something) best regards, w3b5urf3r Edited by user 14 July 2012 01:14:17(UTC)
yes i don't like it either, i mean this global redefinition from within a function, i think this was a change introduced by Andrey for something related to future animation capabilities of smath
Hello.
Yes, this is by design. This feature called Output Arguments and it can be used within procedures (functions defined with line(..) at right). This allows to return any number of values from the function. One just should remember that changing value for the variable of the same name as defined in function's arguments for such functions will also override global value of that variable.
Regards.
I don't get this Originally Posted by: smath One just should remember that changing value for the variable of the same name as defined in function's arguments for such functions will also override global value of that variable. I am running into a problem where I have f(x,y):=2x+y When I define x:=? and y:=? I get the correct result. However, WHEN I re-define x and y and reuse the function, the answer is ALL over the place. Can someone give an example explaining what Aundrey ment (see quote)
Originally Posted by: ElSid I don't get this Originally Posted by: smath One just should remember that changing value for the variable of the same name as defined in function's arguments for such functions will also override global value of that variable. I am running into a problem where I have f(x,y):=2x+y When I define x:=? and y:=? I get the correct result. However, WHEN I re-define x and y and reuse the function, the answer is ALL over the place. Can someone give an example explaining what Aundrey ment (see quote) Hi, I think that the image below could be useful to explain the behavior Using f(a) the input variable - x, will be modified by the function; Using g(a) the input variable - y, doesn't change. regards, w3b5urf3r Edited by user 23 October 2012 21:22:52(UTC)
| Reason: Not specified Davide Carpi attached the following image(s): |
w3b5urf3r See file I attached while you responded. See the grey non print area for page 2 and 3
Originally Posted by: ElSid w3b5urf3r See file I attached while you responded. See the grey non print area for page 2 and 3 I see It's not related with the behavior of this topic, but with this: local and global variablesSimply change your function giving as input all variable parameters - so add: k.ins, k.pipe (and others, if needed) regards, w3b5urf3r Edited by user 23 October 2012 23:28:09(UTC)
Quote:Simply change your function giving as input all variable parameters I had combined various sheets into one sheet and totally spaced the fact that the other variables were changing. Originally, the k's were fixed.
