Offline RegRetired
#1 Posted : 08 July 2023 08:43:26(UTC)
RegRetired
My Mathcad brain causes me to misunderstand some SMATH syntax. The is especially true in XY-Plots. I have created two function: F(s) and F1(s), which is discontinuous. If I redefine the functions as vectors and use augment to define the x-axis, the plots look okay. However, when I try to plot just the function, it does not work. These plots do not create a trace list as with the vector versions. F(s) just doesn’t plot. F1(s) also doesn’t plot, plus it gives an error.
In short, how do I plot simple functions?
Any help is appreciate, as always.
Plot Functions Question.sm (13kb) downloaded 8 time(s).
Reg Curry
Loveland, CO
Offline Razonar
#2 Posted : 08 July 2023 09:33:26(UTC)
Razonar
Uruguay
Was thanked: 826 time(s) in 523 post(s)
Hi JReg. If I'm not wrong, just try to plot both with an undefined variable like F(so) and F1(so). The problem is that 's' is a vector.
Offline RegRetired
#3 Posted : 08 July 2023 13:28:35(UTC)
RegRetired
Razonar,
Thanks much. That works.
Hope you don't mind if I have a second question.
In this attached sm file, I calculate the solution to an ODE with those two driving functions. Note the last integral in the solution. If I use F(s) it works; however, F1(s) is the function I want in the integral. For some reason it does not work. You will have to change F to F1 in that last integral to see that it fails.
Have I missed something obvious?
Thanks again. EMISSION REDUCTION Test.sm (29kb) downloaded 13 time(s).
Reg Curry
Loveland, CO
Offline StvMath
#4 Posted : 08 July 2023 16:39:50(UTC)
StvMath
United Kingdom
Was thanked: 24 time(s) in 21 post(s)
It works if you define F1 as: F1(z):=(M*(z-tstart)+Fexp(tstart))*(z≤tfinish)+Fexp(tfix)*(z>tfinish)
i.e. using Boolean values: (z≤tfinish) = 1 if true, 0 if false, etc.
Don't know why SMath has a problem integrating if.. else.. structures.
Offline RegRetired
#5 Posted : 08 July 2023 19:45:07(UTC)
RegRetired
Thanks. I’ll give that a try.
Reg Curry
Loveland, CO
Offline RegRetired
#6 Posted : 08 July 2023 21:56:23(UTC)
RegRetired
Thanks again. That really helped.
Reg Curry
Loveland, CO
#7 Posted : 09 July 2023 13:45:20(UTC)
Smath integrates if/otherwise discontinuous functions.
Bolean must be specified completely, if NOT navigates.
Integrate Discontinuous.sm (37kb) downloaded 9 time(s).
Offline uni
#8 Posted : 10 July 2023 10:22:25(UTC)
uni
Was thanked: 1275 time(s) in 746 post(s)
Due to the implementation features, you can't use the function argument the same way you do it in Mathcad. The component allows you to use a vector variable if you add a tilde before the name.
Plot Functions Question (uni).sm (15kb) downloaded 10 time(s).
Russia ☭ forever
Viacheslav N. Mezentsev
