Offline OchkovVF
#1 Posted : 03 June 2023 14:48:30(UTC)
OchkovVF
Was thanked: 26 time(s) in 25 post(s)
I can it solve in Mathcad - see please mcdx and pdf files
I try solve it (heat transfer) in SMath - see sm file
Help please
Kerimov-Cvetkov-Velichko-1-7.pdf (96kb) downloaded 8 time(s). Kerimov-Cvetkov-Velichko-1-7.pdf (96kb) downloaded 7 time(s). Kerimov-Cvetkov-Velichko-1-7.mcdx (951kb) downloaded 3 time(s).
Edited by user 03 June 2023 14:58:49(UTC)  | Reason: Not specified
Offline overlord
#2 Posted : 03 June 2023 21:37:44(UTC)
Turkey
Help please
SMath symbolic solving of integration is not capable as Mathcad.
Thus integrals can't be used with numeric solvers.
However, you can use a little trick to solve them.
Using maple or maxima plugins is the key.
Here is your problem solved with various ways, roots() and Findroot().
solvewithunits.sm (24kb) downloaded 23 time(s).
thanks 3 users thanked overlord for this useful post.
on 03/06/2023(UTC),  on 04/06/2023(UTC),  on 04/06/2023(UTC)
Offline Razonar
#3 Posted : 04 June 2023 08:18:41(UTC)
Razonar
Uruguay
Hi. The attached have an al_nleqsol wrapper for a Mathcad block with units, that can accept SMath's integrals too.
Click to enlarge
Kerimov-Cvetkov-Velichko-1-7 - nSol.sm (18kb) downloaded 21 time(s).
Offline overlord
#4 Posted : 04 June 2023 16:00:56(UTC)
Turkey
Actually, you don't need to find Tc2 first hand.
Findroot() can solve with all three equations at once.
All important is the order of unknowns.
thanks 2 users thanked overlord for this useful post.
Offline overlord
#5 Posted : 05 June 2023 06:08:21(UTC)
Turkey
Here is a paper-friendly version.
Also check how variable guess points are assigned.
on 05/06/2023(UTC)
Offline OchkovVF
#6 Posted : 05 June 2023 08:24:02(UTC)
OchkovVF
Thanks!
Send please the sm file.
#7 Posted : 05 June 2023 17:08:24(UTC)
Hello Valery,
In some application(s), you can associate FindRoot with epsilon.
Solve Diophantine Chemical Balance epsilon.sm (107kb) downloaded 10 time(s).
on 05/06/2023(UTC)
Offline overlord
#8 Posted : 05 June 2023 23:39:04(UTC)
Turkey
Thanks!
solvewithunits.sm (15kb) downloaded 17 time(s).
Offline netsonicyxf
#9 Posted : 26 June 2023 08:33:01(UTC)
netsonicyxf
Please help, why can't find root for this simple equation?
root.sm (21kb) downloaded 8 time(s).
#10 Posted : 26 June 2023 11:54:06(UTC)
Because there aren't unknows
#11 Posted : 26 June 2023 14:45:01(UTC)
Please help,
why can't find root for this simple equation ?
roots solves wrt scalar function(s)
In this example, both functions are scalar wrt 'x'.
Try ... roots[(sin(x)-Gamma(x),x,1]
'x not defined' ... Gamma(x) is not scalar wrt 'x'
Few more numerical functions are not scalar
erf(x), erf(x,n) ... erfc(x), erfc(x,n) ...
#12 Posted : 26 June 2023 14:55:02(UTC)
In that case and similar ones,
RootSecant algorithm will spits out 15 decimals, instantaneous.
Offline netsonicyxf
#13 Posted : 26 June 2023 16:06:59(UTC)
netsonicyxf
Thanks Davide.
Now I put "N" as unknown in the Eq. But it can't be solved either.
root.sm (20kb) downloaded 5 time(s).
Edited by user 26 June 2023 16:08:32(UTC)  | Reason: Not specified
#14 Posted : 26 June 2023 16:58:58(UTC)
You have to play a little with the precision, especially if there are units involved; in this case, seems that 10^-3 mm is a stable target (10^-2 works too, but in some case it returns the guess value, meaning that is "close enough" for the algorithm - you can see in the plot that 0kN to 200kN is in +0.02/-0.02mm range)
root_r1.sm (25kb) downloaded 6 time(s).
Edited by user 27 June 2023 11:18:01(UTC)  | Reason: Not specified
on 26/06/2023(UTC)
