SMath Studio Forum
Questions
Units in variables from a matrix
Hi
I have a dataset (using Excel-file as a source) from where I get values with vlookup, but I am unable to set units properly.
Values retrieved from a matrix have these square brackets around them [], and it makes working with units really difficult.
I was able to convert mm to m (my database has plain values, but they are supposed to be mm). But next step is to display final results in kN/m, but I keep getting kg/s^2.
I am able to remove units completely and display the correct result without units displayed, but this is suboptimal.
EDIT: I'm using importData plugin
Suggestive ...
Joined: 23/07/2013(UTC) Posts: 1,129 Was thanked: 510 time(s) in 340 post(s)
You either need to alter your dataset or do corrections after import. I am not promising anything but maybe units can be imported as they are. But we need your dataset and smath file for to check if it can be done.
Joined: 28/08/2014(UTC) Posts: 1,368 Was thanked: 828 time(s) in 525 post(s)
Originally Posted by: RC_eng ... I was able to convert mm to m (my database has plain values, but they are supposed to be mm). But next step is to display final results in kN/m, but I keep getting kg/s^2. ... Hi. Something like this? Best regards. Alvaro.
Originally Posted by: Jean Giraud Suggestive ... ... Think in terms of sub-utilities you may need to apply.
Originally Posted by: Razonar Hi. Something like this?
Best regards. Alvaro. My guess is his data is something like this. That's what I deduce from his description at least. Without him posting datasheet we can't help any further.
Worksheet1.sm (8kb) downloaded 7 time(s). data_forum.xlsx (9kb) downloaded 7 time(s).Thanks for your replies, here are the files. I would like to display variable z as kN/m instead of that kg/s^2 Edited by user 12 June 2023 09:32:35(UTC)
| Reason: wrong files attached
You have to customize the result units in the rightmost placeholder. |
Originally Posted by: Davide Carpi You have to customize the result units in the rightmost placeholder. Thank you! I don't know how I didn't get that working couple days ago, I tried to write units outside of brackets but didn't succeed. But now it works no problem
You're welcome |
SMath Studio Forum
Questions
