Joined: 03/06/2023(UTC) Posts: 45 Was thanked: 1 time(s) in 1 post(s)
Is there an easy way to scroll through a very large matrix? Thx |
Reg Curry Loveland, CO
Originally Posted by: JReg Is there an easy way to scroll through a very large matrix ? Very easy as suggested. Page8 Scroll Matrix.sm (3,615kb) downloaded 7 time(s).
If you can't download attached documents, can you attach your big matrix ? Describe/explicit your demand.
Scroll matrix ... quick/quick/done
Originally Posted by: JReg Is there an easy way to scroll through a very large matrix? Thx Hi. I guess that the effort less way is putting the matrix into a Table region, and using the 8 three dots that appear at borders and edges for navigating in the matrix. Best regards. Alvaro.
Originally Posted by: JReg Is there an easy way to scroll through a very large matrix ? Answer is YES matrix ... NO w/o matrix. That means, attach your large *.sm matrix.
I like the idea of tables; however, as far as I can tell, it will not do continuous scrolling. Maybe I am missing something.
Reg
Jean, I am having trouble understanding how to use your sm file. |
Originally Posted by: JReg Jean, I am having trouble understanding how to use your sm file. Download this one, confirm you can open. Simply a bit more descriptive, cross hair helper from Padding the region Padding is what we use to zoom Fourier a gray or RGB image, up to zoom 2. For larger zoom, I use IrfanView or WinGrab. Cheers ... Jean. Take Care. Image Matrix Scroll Region Copy.sm (3,974kb) downloaded 8 time(s).
Originally Posted by: JReg Maybe I am missing something. You are not missing anything. There is no continuous scroll for table region. Regards
